Toyota Land Cruiser Prado 150 series
#31
I checked on the net, but I cannot without doubt see if the Prado is marketed in the US. Except for the Lexus GX, is it marketed under a another guise? Here it was a cult and to a certain degree still is. In a certain sense it is a vehicle in it's own class (nowadays outsold by the cheaper Toyota Fortuner). The Prado is very, very luxurious and yet a hard core pukka off-roader, in which you can really drive through Africa.
#32
#33
The thing is with the Prado, its high quality, but apart from that you get off-road hardware in it that is mostly optional in a lot of vehicles that is the same price and not nearly as capable in the bush. On the downside it is not particularly roomy inside and the previous Diesel engine, namely the KZ-TE was lazy and a Diesel gussler of note. Nowadays with the D-4D engine its much better. In my mind a good buy. The Fortuner is of course a much more basic vehicle and actually an on chassis SUV of the Hilux pick-up truck (the one that Jeremy Clarkson tried to destroy on British Top Gear, but failed). It however outsells even VW and Toyota hatchbacks here. Strangely, but maybe because of the RHD it is only available in South Africa, Malaysia, Malta etc. But, yes, it sort of dented the Prado cult here. Those pics you guys have here, is surely going to make me find an excuse to pop into the dealer's to check it out if it comes in.
#35
Guys, we all have locking diffs, to an extent. The ATRAC system is a smart locker and engages when needed while in 4low, negating the need to press a button or turn on a compressor.
#36
FYI - a locking diff will not help you get out of the snow. You need a tire with traction for locked diff to get you anywhere. If anything, a locked diff will dig you deeper.
#38
Nice thread, interesting read. Thanks for the Crash Videos, I definitely feel safer driving around my new born in the new GX. The GX was purchased as the new FAM Bam Mobile when the little one was born.
#39
So, you're telling us a locking diff "will not help you get out of the snow"? Are you sure about that? 2 tires spinning with open diffs vs. 4 tires spinning with locked diffs will not help in the snow? Sorry, but with dealing with snow and driving many different vehicles with open diffs and locked diffs I'll take a locked diff any day over open in the snow, mud or sand. Yes, I agree a good tire will always have a lot to do with it but 4 tires pulling you out will be much better in most situations.
#40
Yes, I'm sure about that. I'd rather not get into a debate, I was simply offering up some advice, we can agree to disagree. Our trucks are full time 4wd. At no point will you have just 2 wheels getting power to them. Open diffs on a full time 4wd vehicle allow the majority of power to be distributed to the wheels with the least amount of traction - this is done to prevent wheel spin. Locked front and rear diffs will make each wheel turn at the same rate, regardless of traction. If you are in a snow drift where all 4 wheels are missing traction, locked diffs will only make your problem worse.
That's what it's all about, we in America can have different Ideas and be able to voice them.
#41
Not trying to nitpick here but for all wheels to turn at the same rate you need three differentials locked -- rear, front and center. Just locking front and rear diffs won't result in each wheel turning at the same rate because the center will remain open.
#43
Nice find, love it!!! Thanks for sharing.
