Toyota Land Cruiser Prado 150 series
#106
The GX shares components, and thus you can take aftermarket stuff for the runner and put it to use on the GX. One member posted their Icon lift kit here if you search. Its always a plus if you dont have the rear air suspension
#107
Super Moderator
I think the KDSS also limits some lift options.
EDIT: Saw some 4Runner threads where one has to use a spacer on one side to prevent leaning if you go up 3 inches with a KDSS vehicle. Perhaps some others who have lifted can chime-in if this is the case on the GX.
#108
I have the premium which doesn't have the air suspension.
#109
Super Moderator
'18 Prado specs
Quite a range for bug out vehicle
https://www.motoring.com.au/three-to...-prado-109155/
Petrol dropped and diesel only in Australia
Towing capacity: 3000kg (6,613 lbs)
Power: 130kW (174 HP)
Torque: 450Nm (331 Ft lbs)
Range: up to 1,800km (1,118 miles)
"Toyota has also quashed rumours it will axe the popular SUV’s 63-litre sub-tank, which in addition to its 87-litre main tank brings fuel capacity to 150 litres.
That’s enough for a theoretical range of 1800km-plus and makes the 150-series LandCruiser Prado one of the few off-road SUVs able to undertake long-haul off-road treks like the Simpson Desert without the need to carry extra fuel."
#110
I do like the look of it much better than the hideous front grill/bumper that we get here. Not sure the wife would care for the diesel, but I probably would. From the pictures, it looks like it may have a bit more ground clearance under the running boards. I have seen them in my travels over seas, but never really got to explore one closely. Although, except for s few locally desire changes, they are pretty much the same. Diesel vs gas, manual availability vs automatic. And all the safety stuff we get here might not be offered elsewhere in the world. As well as emissions stuff we get here. Sure would be fun, to have cars side by side from around the world to compare in person. Drive them etc.
#111
Super Moderator
The 3 door GX 460
I think this was discontinued years ago. Reminds me of what Isuzu did in the day with the Trooper. They used to have a 3 door version of that in the early 90's.
https://www.toyota.com.au/static/veh...door_saver.pdf
The old Isuzu Trooper
#113
Super Moderator
It could also be short wheelbase off-road competitor to the Wrangler and Ford's upcoming 2020 Bronco
Acrad (01-22-18)
#115
Super Moderator
#116
What is up with those wheels? This is a cheaper model than posted earlier here.
#117
Super Moderator
This is the Mazda Navaho version :-)
#120
Super Moderator
