3rd row seat removal
#31
Super Moderator
It appears that module on the middle of exposed rear floor on 3rd seat removal is for the smart key system
PN: 899A0-60020 / Antenna Assy, Indoor Electrical Key
#32
I kinda figured that because if my key is a foot or so from the back door I can't use the lock button on the gate. I have to stand back from the door 2-3 feet to lock it.
Acrad (10-16-18)
#33
Super Moderator
Interesting... stock placement is there for a technical reason
#34
Super Moderator
If one wants to take second row bench out as well. Instructions attached.
Joni1007 (05-01-21)
#35
Super Moderator
GXOR member selling his 3rd row after installing this Goosegear plate system. Another option if you don't use 3rd row and want to reclaim space. They don't have a 460 pic on their website.
https://www.goose-gear.com/collectio...-470-2002-2009
The following 2 users liked this post by Acrad:
Joni1007 (05-01-21),
JoshDrivin (09-02-20)
#36
Super Moderator
PachariAdv (09-02-19)
#38
I watched this video yesterday and even though it has been awhile since I have done this it looks like this guy removed more than needed.
tigmd99: The seats are removed to put something else in its place so that probably evens out the road noise.
#39
Thanks for watching the video. I definitely took out as much as possible wanted as much possible space for the drawer system I'm putting back there... might end up putting some things back, like the little wing trim pieces, depending on how the whole thing shakes out... it's been quite the project, probably should have just bought the Goose Gear system. Oh well, learning new stuff!
Acrad (09-09-19)
#40
Just finished building my rear deck, after finding this post (http://www.dewijn.net/preparation/ge...ms-boot-ready/). Ended up making it in two pieces since the side wings wouldn't fit while attached and this way I can reinstall one of the rear seats down the road, if needed. The passenger side is slightly wider than the driver to accommodate the plastic trim on the seat. Drawers will be next, but need to find some better carpet. I got this off Amazon but not very happy with it.
#41
#42
Super Moderator
Owner was selling it last year
https://www.facebook.com/groups/Lexu...74416626022778
#44
#45
Third row seat removal
Started with a 2014 GX 460 Premium (yes, I took the roof-rack off but that's for another thread)
Reviewed "Getting Liam's Boot(y) Ready" for some inspiration
Removed the seats
Screwed three 2" x 2" support blocks to existing bolt holes originally for seats, so no new screw holes. Not pictured is a quarter-inch piece of wood running most of the width across the cargo entrance, just inside the lower threshold of the cargo door between the rubber door seals and the electrical bundle, for extra stability & to visually cover the gap at the back when the plywood board is on top.
Placed a half-inch thick 41" x 42" plywood board on top. Not pictured are the two small boards I cut to close the large gaps on the left & right next to the wheel wells, cutting the tops of the boards at a slight downward angle towards the rear to match the slight downward angle & height of the padded shelf next to them.
Covered all the wood, except the three already-screwed-in support blocks underneath, with inexpensive material from Home Depot using my staple gun. (I know the color doesn't match but it's easy to re-cover with something that does if it ever bothers me or gets trashed) THEN screwed both side boards to the side of the plywood board, THEN screwed the plywood board onto two of the back floor support blocks (left & right) with two additional screws towards the front (left & right) that fit & grip the pre-drilled holes on top of the small metal rise that stretches across the width.
Nothing fancy, just inexpensive, tough & practical. The dogs love it.
Removed the seats
