5k vs 6k VLeds?
Old 04-20-14, 11:28 AM
ohiois350
ohiois350's Avatar
Thanks Tecman, i just pop out the dome light covers, and noticed all the bulbs point down, therefore, i order 3 sets of these bulbs http://www.vleds.com/shop-bulb-numbe...58-1-pair.html for dome lights
2 set of flank type bulbs for four doors http://www.vleds.com/shop-bulb-numbe.../5k-4-hpf.html
And 2 sets for running board http://www.vleds.com/shop-bulb-numbe...-led/6-5k.html
And 921 for back up, and i choose 5k, since i already have 6k to compare with one i like it better
http://www.vleds.com/shop-bulb-numbe...79-1-pair.html
ohiois350 is online now
Old 07-28-14, 07:03 PM
T4Fun
T4Fun's Avatar
so how do you like the leds. have to switch mine all out again. Bot some in 2010 but running board lights were not that bright
T4Fun is offline
Old 07-28-14, 07:07 PM
T4Fun
T4Fun's Avatar
Originally Posted by tecman
I used some reflectors to eliminate the directional problem.
which leds did you use? those are very bright!
T4Fun is offline
Old 07-28-14, 10:19 PM
ohiois350
ohiois350's Avatar
yeah those bulbs are bright and white, i like it more than my 6k colour that on my
IS now
Old 07-29-14, 05:31 AM
tecman
tecman's Avatar
tecman is offline
Old 07-30-14, 05:42 AM
NoDak
NoDak's Avatar
I used 5k from vleds, the 6k had too much blue in them for my taste.
5000 horizon daylight
5500-6000 overhead daylight
6500 overcast daylight
NoDak is offline
Old 08-04-14, 12:18 PM
Jake
Jake's Avatar
I put these in our GX about a month ago. It's hard to get the coloring to really show.
I'm not totally in love with it with the Sepia interior, but I don't plan on changing it back.
For those of you who're wondering all you need are 16x T10 wedge bulbs.
Attached Thumbnails 5k vs 6k VLeds?-img_9935.jpg   5k vs 6k VLeds?-img_9936.jpg   5k vs 6k VLeds?-img_9938.jpg
Jake is offline
Old 08-05-14, 07:55 AM
NoDak
NoDak's Avatar
2013 GX460 bulb list, should be the same for the 2014 and older same gen cycle.
Back Up Light Bulb - 921
Courtesy Light Bulb - 168
Daytime Running Light Bulb - 9005
Dome Light Bulb - 168
Fog Light Bulb - H11
High Beam Headlight Bulb - 9005
Low Beam Headlight Bulb - H11
Map Light Bulb - 168
Parking Light Bulb - 168
Front Side Marker Light Bulb - 168
Rear Side Marker Light Bulb - 168
Rear Turn Signal Light Bulb - 7440A
Front Turn Signal Light Bulb - 7440A
Vanity Mirror Light Bulb - 175
NoDak is offline
Old 08-05-14, 09:06 AM
T4Fun
T4Fun's Avatar
i am replacing the high beam halogen with this led light...
http://www.ebay.com/itm/121340946884...84.m1497.l2649
T4Fun is offline
Old 08-05-14, 02:14 PM
tecman
tecman's Avatar
So 2014 has led low and halogen high?
Amazing that those two little leds put out 2400 lumen!
tecman is offline
Old 08-06-14, 03:36 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
please do chime in after observing the results.
yes sir.
GRAND_LS 4 is offline
Old 08-10-14, 07:47 PM
T4Fun
T4Fun's Avatar
well the led light was installed and its output amazing.
problem is the base heat sink too big and the cap on the back of headlight
housing wont fit with this. Just wasted about $70. I can put it in, but i am sure
the screw cap is back there for a reason.
anyone else have any other H9 highbeam LEDS to try out? Make sure base fits
inside housing and you can screw cap back on. I'll post pics
T4Fun is offline
Old 08-11-14, 09:14 AM
T4Fun
T4Fun's Avatar
here are pics.
the leds are nice, but dont fit to allow cap to be screwed back on headlight housing
Attached Thumbnails 5k vs 6k VLeds?-imag0199_burst002.jpg   5k vs 6k VLeds?-imag0216.jpg
T4Fun is offline
Old 08-11-14, 03:39 PM
tecman
tecman's Avatar
It doesn't look like that shallow housing will allow any LEDs to be added. If you recall 2010 through 2013 only had the housing on the low beam and it was full of room so I was able to get everything inside of it on the low beams but I do not have a housing on the high beams or the fog lights. The problem with high output LEDs is that they require a heat sink which is quite large. Pic below is my low beams and fogs with a ballast.
tecman is offline
Old 08-12-14, 11:15 AM
T4Fun
T4Fun's Avatar
heres a very cheap solution for upgrading to leds inside
Amazon.com: Jtech 10x 194 168 2825 T10 5-SMD White LED Car Lights Bulb: Automotive Amazon.com: Jtech 10x 194 168 2825 T10 5-SMD White LED Car Lights Bulb: Automotive
T4Fun is offline
Lexus408
03-06-13 02:25 PM
pfdaxe
02-28-11 08:12 AM
huerdo623
12
05-26-07 05:18 PM
brendanlim
Lighting
41
02-12-04 06:10 PM
Quick Reply: 5k vs 6k VLeds?
