Fuel discussions/questions - Octane Regular or Premium (merged threads)
Old 09-01-10, 07:53 PM
Luke27617
Luke27617's Avatar
Originally Posted by frankfaris
Are any other GX 460 owners experiencing hesitation when accelerating? I live in Arizona where premium gasoline is only 91 octane, and regardless of brand there can be from a one to three second hesitation when accelerating.
Personally I have not experienced this yet, but the issue has been reported.
Here it is a link from some law firm investigating the issue and looking for people who suffer injuries due to this problem You have to love ambulance chasers
http://www.utahjusticelaw.com/lexus-...e-failure.html
Old 09-01-10, 08:37 PM
T4Fun
T4Fun's Avatar
interesting test, will try it out this weekend. my vin is in 15k range, so wonder if this is issue with earlier ones?
Old 09-02-10, 07:39 AM
gsobol
gsobol's Avatar
Is it from a stand still, or while moving (highway speeds >30mph) ?
Old 09-02-10, 10:38 AM
frankfaris
6th Gear
frankfaris's Avatar
VIN is in 5K range. When I was traveling in states where Premium was 93 octane, I did not observe the problem. In states like AZ and CA where premium (regardless of brand) is 91 octane the problem is very obvious in my vehicle.
The problem occurs when accelerating from both a standstill and when accelerating at any speed.
Frank
2009 LX
2010 GX Premium
Old 09-02-10, 10:56 AM
gs400jon
gs400jon's Avatar
No problem in Northern California burning Shell 91 octane.
Old 09-02-10, 05:12 PM
SaniDel
SaniDel's Avatar
Nor in sea-level Delaware using Valero 93 octane, but will report if we notice the problem.
If anything, the GX 460 is too aggressive ... unless we 'feather' the accelerator from a standstill or a slow speed ... it jumps! Impressive and reassuring, but a bit alarming to the passenger.
I've appended the fuel specification from page 752 of the 2010 GX 460 Owners Manual ... premium fuel only, i.e., a minimum of 91 octane. However, on page 762 we are told that "in a pinch" we may use lower than 91 octane, but that may result in engine knocking. Further, persistent knocking may lead to engine damage ... other than that, how did you enjoy the play, Mrs. Lincoln? ;-)
Regards,
SaniDel
Attached Thumbnails Fuel discussions/questions -  Octane Regular or Premium (merged threads)-fuel.jpg   Fuel discussions/questions -  Octane Regular or Premium (merged threads)-fuel-information.jpg
Old 09-10-10, 11:10 AM
cannysage
cannysage's Avatar
it takes quite a bit of abuse to have the engine knock from low octane gasoline. I'm talking going steep uphill, pulling heavy load, consistent WOT (wide open throttle) and so forth. If you're a mellow driver, even a lower octane will suffice (even though i personally wouldn't). I don't think your hesitation is from fuel grade.
Old 09-10-10, 11:23 AM
Luke27617
Luke27617's Avatar
Lexus is investigating the hesitation issue. In the vibration thread (my issue), the dealer has mentioned that they have a rep coming to investige the hesitation and want to show my vibration issue. Personally I have not noticed the issue while going light and when towing 2500 lbs.
Old 09-10-10, 12:40 PM
SaniDel
SaniDel's Avatar
We've been trying to duplicate the problem, but haven't seen it. We've tried some of what 'cannysage' suggests on a long, steep hill on a nearby highway. It is steep enough that the GX 460 can't hold speed on the upgrade without going out of ECO mode and downshifting. We've also tried 'sprinting' up the same hill holding the pedal to the floor ... lot's of fun, but no knocking.
What we can't duplicate is pulling a heavy load as we have no trailer hitch, much less anything to trail. The closest we got was on a recent road trip with three adults and a full load of luggage, but that's hardly the same as pulling a trailer.
Most of the time we would qualify as "mellow drivers" but those few times when we have to "stand on it" to avoid a problem would NOT be good times for the GX 460 to hesitate!
Regards,
SaniDel
Old 09-16-10, 11:13 AM
frankfaris
6th Gear
frankfaris's Avatar
What I have observed that my vehicle performs fine if I am in places where I can get 93 or above octane gasoline, or if I use an octane booster.
Old 09-16-10, 11:43 AM
SaniDel
SaniDel's Avatar
That may explain why we haven't seen any evidence of this problem. Here in sea-level Delaware 93 octane gasoline is readily available at most service stations and Sunoco sells even higher octane at some of their service stations.
Conversely, in western states, which are at higher altitude, lower-octane gasoline is the norm. As altitude increases, air pressure decreases, which has a deleterious effect on engine efficiency, which can be offset to some degree by increasing octane, but only if it is available!
Regards,
SaniDel
Old 09-24-10, 08:36 PM
Luke27617
Luke27617's Avatar
I was at the dealer today and there was a couple who complained about hesitation problem with their truck. It turned up they were using lower grade gas. Looks like our trucks like the premium only and have a sensitive stomach.
Old 09-25-10, 05:35 AM
Koz
Koz's Avatar
Regards,
SaniDel
There is no need to use higher octane fuel at high altitude to compensate for the lower octane in the fuel in that area. At altitude, lower absolute pressure in the cylinder creates less heat when it's compressed, that's why the lower octane fuel will work fine. The only time you would want to use higher octane is if you are experiencing knock/ping. You will loss approx 3% HP for every 1K ft. and using higher octane will not create more power, you will only be wasting your money.
Koz
Old 09-25-10, 05:49 AM
SaniDel
SaniDel's Avatar
Koz
Thanks for the explanation. The relationship between altitude, octane and engine power is more complicated than I understood, but it makes sense and correlates to our experience.
On a long road trip in 1982 from sea-level Delaware to the Colorado Rockies the available octane dropped to as low as 85. Needless to say, our vehicle was sounding like a diesel at idle! I had to buy a set of cheap tools and manually retard the timing. The engine was barely making enough power to get us over some of those mountain passes and on one long uphill climb it gave up ... we coasted to the shoulder until we got it to restart.
Regards,
SaniDel
Old 09-29-10, 05:42 PM
redrocks
redrocks's Avatar
Regards,
SaniDel
1982? Cars have come a long, long way since then.
Quick Reply: Fuel discussions/questions - Octane Regular or Premium (merged threads)
