Fuel discussions/questions - Octane Regular or Premium (merged threads)
Old 07-31-22, 06:47 PM
  #481
DrRock
10th Gear
DrRock's Avatar
I really wish we could do away with ethanol. It has become a sacred cow for those involved with it but it causes issues with vehicles, takes a lot of water, land, fertilizer/pesticides, and energy to process. I have had two Ducati motorcycles that needed multiple tanks replaced because they have plastic fuel tanks and the ethanol causes absorption and swelling of the tank. The Italian designers didn't take ethanol into account when designing the tanks. Sorry for the quick rant.
The following 2 users liked this post by DrRock:
hwang1jin (07-31-22), NewB2Lexus (07-31-22)
Old 07-31-22, 09:16 PM
  #482
ballistice
ballistice's Avatar
It's the bike not the fuel. Sorry you had to find that out the hard way. Ethanol does not do any more damage to tanks than straight gas. Multiple bikes here with plastic tanks and still going strong. Plastic tanks swell naturally when temps and elevations increase.
Old 07-31-22, 11:49 PM
  #483
ASE
ASE's Avatar
Received 1,033 Likes on 690 Posts
Ethanol absorbing water and breaking down causes a range of problems. Best to use non-ethanol fuel ... or keep refreshed by consuming inside of 60-days.
DrRock (08-01-22)
Old 08-01-22, 04:34 AM
  #484
DrRock
10th Gear
DrRock's Avatar
Actually no it is the fuel but thank you. Ducati’s tank maker changed to a different type of plastic Around 2010, but from 05-10 ethanol sitting in the tanks would cause swelling and blistering. If you google this you will find much more info but here is one.
  • If the Ducati has a plastic tank and you are in North America: Check for swelling in the tank, like bumps and blisters, or the tank bulging asymmetrically. If the latch is hard to open, or if the tank is too close to the ignition shroud, it’s a sign of swelling. Swelling in the plastic tanks was caused by ethanol mixed into North American gasoline. It was a known problem, and for a while, Ducati was offering replacements. If your tank has no swelling, it may have been replaced (which is good). Of course, if the owner has evidence of this, all the better.
Old 08-01-22, 05:50 PM
  #485
John00
John00's Avatar
the octane rating on the pump isnt what it has to be, its the minimum it has to be. a majority of the time you will get a higher octane than the label if you use the lowest value. this is because more often than not it is cheaper to just make the mid and high grade instead of 3 separate process lines.
Old 06-18-23, 01:58 PM
  #486
userlexusgx
1st Gear
userlexusgx's Avatar
Can I mix my 2015 lexus gx460 with 87 and 93 octane to make 90 octance?
Old 06-19-23, 03:27 AM
  #487
bootman
bootman's Avatar
https://www.cars.com/articles/mix-re...e-pump-448191/
Old 06-19-23, 05:41 PM
  #488
catdaddylo
catdaddylo's Avatar
I have been doing this for all of my vehicles that require 90 octane. I keep the recite when I fill up my tank and write the octane on it and place it in one of the cup holders. When my tank is half empty (full) I fill up with the octane that will keep my tank at 91. I do this for my in town driving. On road trips I use the high octane every fill up because I don't stop for gas until my tank is almost empty.
Old 06-21-23, 04:22 PM
  #489
John00
John00's Avatar
LOL seems like more time than benefit., >180,000 miles, I always use the lowest. never ever noticed any knock. seems the ECUs keep it under control.
Old 06-21-23, 04:43 PM
  #490
ASE
ASE's Avatar
Never understood the controversy on this subject ... knock sensors in modern vehicles will retard the ignition to prevent detonation so as to prevent engine damage. Gasoline has an energy value ... no matter the octane ... all exactly the same ... but with higher octane, the engine can advance the timing for maximum power under high(er) load conditions ... so yes, higher octane does provide increased engine output under these circumstances ... but for anything less than towing or under heavy load like climbing hills or under heavy acceleration and such ... the 89 mid-grade (87-89-93) is just fine for commuting.
John00 (06-21-23)
Old 06-22-23, 07:57 AM
  #491
NewB2Lexus
NewB2Lexus's Avatar
I also never understood someone spending $60-70k on a luxury vehicle then trying to save $10 when paying $100 to fill up at the pump. Assuming you get 400 miles out of a full tank that is a whopping $2500 saving over the course of a 100k miles or a whopping $5000 saving over the expected useful lifetime (200k miles) of the vehicle.
But of course it is a personal choice, while I did fill up the GX with regular a few times (station was out of premium) most of the time I use what's recommended by the manufacturer.
IanG (06-22-23)
Old 06-22-23, 08:23 AM
  #492
John00
John00's Avatar
I cant believe someone in this day and age would spend 70k on a used 2010, then think that higher octane actually helps in any way. It actually accelerates fatigue failure in certain polymers in the fuel train.
Old 06-22-23, 08:40 AM
  #493
NewB2Lexus
NewB2Lexus's Avatar
I only believe this when you post some educated proof of it and that the GX, which was designed to use premium fuel, will suffer negative consequences of using such.
Old 06-22-23, 09:49 AM
  #494
ASE
ASE's Avatar
Originally Posted by Hehena
Maybe, but a lot of us are used GX buyers. My GX was $29k and I use 87 all the time. It runs just fine.
plus I just don't care lol
89 for commuting ... 91-93 for heavy loading ... towing or accelerating over mountain passes. Simple. 87 octane is for Lawn Mowers ... or for those that simply do not care ... the knock sensor will adapt accordingly. Just make sure to use "Top-Tier" gasoline no matter the octane.
Old 06-22-23, 10:03 AM
  #495
ASE
ASE's Avatar
Weird how the truck still works after all this lawn mower fuel, strange for sure.
The Knock Sensor retards the ignition to prevent engine damage ... with the associated reduction in power output. All good if maximum engine power is not required.
We're not talking about a pre-knock-sensor vehicle here ... where the ignition timing is a fixed profile based on RPM's ... where octane is a major consideration when dealing with high(er) compression ratios.
Quick Reply: Fuel discussions/questions - Octane Regular or Premium (merged threads)
