Fuel discussions/questions - Octane Regular or Premium (merged threads)
Old 02-11-14, 07:02 PM
  #91
FrigginFGO
FrigginFGO's Avatar
There was issue with 2007-2010 Toyota FJ Cruisers in which Toyota initially recommended premium fuel for the vehicle. Members of the FJ forum began hassling Toyota about the reason for this since the Tacomas and 4Runners used the same engine but used regular fuel. Toyota eventually sent out an e-mail stating that FJ Cruisers for those model years would have no issues using regular fuel.
That being said, I have always used premium fuel in my 2007 FJ Cruiser. There are members of the FJ forums that use regular fuel, but noted a decrease in engine performance and power loss. It's not significant since some FJ owners can live with that, but it is noticeable. I'd rather use my engine's full potential.
Old 02-11-14, 08:02 PM
  #92
T4Fun
T4Fun's Avatar
Originally Posted by GoHuskers
Does it really make a different? Try it and conclude yourself? Even at $8/tank if you pump twice a week it will add up. Shell Premium 91 is $.55 per gallon more than Shell 87 here.
Ever wonder why 2010 and 2011 RX350 recommended (not required) Premium but 2012+ RX350 recommends Regular? Same for the ES line.
The 4.7L in the GX470 is the same as the 4.7L in the Tundra and 4Runner but the Lexus asks for Premium while the Totoya asks for Regular. Same thing as 4.6L in Lexus and 4.6L in the Tundra.
Premium MAY help the engine running smoother and Lexus wants its customers to feel that way (at the customer's expense).
engines may physically be same, but they are tuned differently
Old 04-06-14, 08:33 PM
  #93
T4Fun
T4Fun's Avatar
Default Is our gx engine compatible with 15% ethanol fuel
saw something on the news saying govt may mandate higher ethanol levels for gas and that it may damage engines and manufacterers will void warranty.
sorry. found answer. NO.
http://hotair.com/archives/2014/02/0...-use-e-15-gas/
mods can delete this thread if you want
Old 04-07-14, 10:54 AM
  #94
Craig B
Craig B's Avatar
No, I think it's only rated for 10%.
Old 04-28-14, 09:30 PM
  #95
pointman
pointman's Avatar
Lightbulb Fuel Questions - Premium or Regular
I wanted to get some feedback as to whether any of you have used regular unleaded (87), premium (89), super (91) or super plus (93) with your GX's or similar models?
Have you noticed a difference between either? The manual calls for premium but the gas tank cover only shows not to use low grade (85).
I currently use 91 but wondered if anyone uses any other grades and if there's any difference in mileage or performance.
Old 04-29-14, 05:48 AM
  #96
Lolrax
Lolrax's Avatar
The car will just become less powerful to prevent knocking if you use lower fuel. It shouldn't hurt anything, but who wants less power?
Old 04-29-14, 12:44 PM
  #97
Craig B
Craig B's Avatar
I always use Mobil 93 octane in mine...
Old 04-29-14, 07:33 PM
  #98
MyGX460
MyGX460's Avatar
They recommend premium gas. .. But incase if you can't find any gas station with it , it is okay to use 85 grade but not recommend .
Old 05-01-14, 05:29 PM
  #99
KULEGOS
KULEGOS's Avatar
I use unloaded 87 no problem , no knocking no issue
Old 05-01-14, 05:41 PM
  #100
pheonix72
pheonix72's Avatar
You meant "unleaded". Like other members said, you will feel some power lost. The knock sensor will adjust. Personally, I would use what ever grade the car manufacturer recommended. I use premium (91) on my 2006 IS350 and the wife's 2013 RX350 uses Regular (87).
what the gas cap indicates is DO NOT use E85 (gasoline with 15% ethanol). That is a complete different type/grade of gas
Old 05-01-14, 06:22 PM
  #101
tecman
tecman's Avatar
I will race you and you can use your gas and I will use the premimium recommended
See the last thread on this.
https://www.clublexus.com/forums/gx-...s-regular.html
Old 05-01-14, 06:39 PM
  #102
davidc2
davidc2's Avatar
Default Absolutely
You'll get a carbon buildup inside that makes it run like ****.
Old 05-01-14, 07:53 PM
  #103
MyGX460
MyGX460's Avatar
$60k car and trying to save .20cents PG? ..lmao
Old 05-02-14, 06:42 AM
  #104
MyGX460
MyGX460's Avatar
So you save about $4.60 per tank....
Old 05-02-14, 07:05 AM
  #105
sanf
sanf's Avatar
bottom line is, the car will still run . It's totally up to you
Quick Reply: Fuel discussions/questions - Octane Regular or Premium (merged threads)
