DIY GX460 Stock Speaker Upgrade
#257
Update:
Finally upgraded dash speakers. Used Kenwood for center speaker and corners Alpine S-S40. Went with 4" for corners because someone already did 4" instead 3.5". They fit but super tight.
Well, difference is noticeable but it's not "Wow". Highs are much clear and as someone already mentioned center Kenwood is giving more bass. I have feeling like there is no bass at all from dash corners besides highs.
Overall improvement is 15-20%. Took me 1h to do everything.
#258
stock ml subwoofer is blown. going to try and fit a SEAS Prestige CA26RE4X 10" in the stock location tomorrow. its a high sensitivity 80w max woofer out of norway, they make awesome drivers. im thinking it will be a good fit and the stock amp should drive it well enough.
#259
Hi everyone,
Just purchased GX460 with non ML sound system. I can say they don't sound that bad, maybe little better than sound on my G35 bose but biggest concern was that i wasn't getting bass on rear but after i read topic found out it's head unit.
After i read this topic i see all of you guys went with different options. I was thinking going with Kenwood for all of them:
Front: Kenwood KFC6996PS 6x9:
Rear: Kenwood KFC1696PS 6.5"
Dash: Kenwood D101 4" (Since i saw that someone installed 4" instead 3.5" decided to choose this
Still didn't order them but would like to hear opinions. My focus is clear sound, i don't need huge bass punch but would like as well clear bass.
Any advice, suggestions are welcome. I am aware that topic started while ago but there might be members still in; hopefully.
Thanks!
Thanks!
#260
intlmike (10-02-22)
#261
I used a Pioneer TS-D10LS4 D-Series 10" 4-ohm shallow-mount subwoofer at Crutchfield in a Mark Levinson box. The speaker fit perfect just had to drill some new holes for the screws. I do not have a Mark Levinson system, so don't know how it would work with the factory amplifier. Just throwing out options for you.
after your install about how much clearance did you have left between the plastic panel and the subwoofer surround/cone? in the specs for your sub says its about a 1/2in thick from the mounting surface. based on
your pics it looks like thats about as thick as you can go without interfering with the interior panel. the dang mounting holes are 2mm off. im going to either drill new holes like you did or try to make an adapter plate to fit the seas woofer but i might not have the room. I didn't want to drill into the enclosure but if it worked for you i might do it. what type of screws did you use?
intlmike (10-02-22)
#262
i saw your thread on your install. very cool and i might do a similar install later on with a aftermarket amp. for now I just want to improve the lower register with the factory amp.
#263
just my 2c. the stock sub enclosure screw holes are reinforced and use special thread forming screws, pretty nifty, they form perfect wide threads. to drill new holes in the enclosure you only have about an 1/8 inch of plastic to screw into. it has worked for some I see, but I wasnt comfortable with the potentiall weakness. seems like no aftermarket subs will line up with stock. the overall diameter is just a little shy of the standard. I chose to drill new holes in the subwoofer itself. was tedious but in the end you maintain stock structural integrity. most are aluminum so they are easy to drill. you also might get away with just wallowing out the existing subwoofer holes and using large washers.
a good amount of engineering went into this screw, from the wide thin threads to the bevels in the shaft to flow the plastic properly to approach maximum strenght.
not saying my way is better than others, just putting it out there.
also, 1/4 in male quick disconnects work as an adapter for the stock subwoofer wiring plug. easily available at any hardware store.
#264
I reached out to the folks at https://www.parts-express.com/ for a replacement non-ML 6 ohm front center speaker, for the minimal clearance issues.
They recommended I try the 8 ohm, 4" Visaton R10SC https://www.parts-express.com/Visato...-8-Ohm-292-597.
Made in Germany.
Parts Express provided great customer service on this and other items.
Sounds clean, bolts right in with no mods.
I feel its worth the shot.
Made in Germany.
#265
Since this thread still seems to be fairly active, I just got a 22 GX without the ML audio, and wanted to keep it going.
I really just want to start with adding a subwoofer. I didn't see an amp under either front seat, so wondering if anyone with a 2022 GX has added a sub, and where they tapped the signal. Also, did you mount any aftermarket amp under the front seats or somewhere else? Seem like the only place at first glance, but it would also be in front of the underseat vents.
As far as speaker replacements, anyone try these JL Audio 6x9's:
Anyone who has replaced their front mids with a coax, do high range sounds also come out? According to Crutchfield notes, the 4" corners are only mid range, and the 6x9 door are only lower range frequencies.
thanks!
"Starter component speakers like no other"
https://www.crutchfield.com/p_13699046/JL-Audio-C1-690.html?tp=105- component speaker system includes 2 woofers and 2 tweeters
- 6"x9" injection-molded mineral-filled polypropylene woofer cone with rubber surround
- separate 1" aluminum edge-driven dome tweeter with in-line high pass filter
- handles up to 60 watts RMS (225 watts peak power)
- frequency response: 39-22,000 Hz
- sensitivity: 94 dB at2.83 volts
- top-mount depth: 2-3/4"
- grilles not included
- warranty: 1 year
thanks!
#266
Just picked up a 2019 and have already ordered most of the parts I need.
My question:
In my studies of the audio system wiring, I see that the tweeter and the 4" dash speaker are actually wired together in parallel (see screenshot below). In other words, there are no wires going directly from the amp to the tweeters... Is there a passive crossover wired in between these two speakers?
- Infinity Kappa component 6x9s for the front doors/tweeters
- PRV Audio 4" for the dash speaker (taking a gamble here, very good reviews and high sensitivity)
- Audiocontrol lc-6.1200 amp
- JL Audio cs113tg-tw5v2 subwoofer
- Pac Audio APH-TY02
My question:
#267
My question:
My question:
#268
Keep us updated on the install. I also just bought a 2019 GX460 after having a 2017 ES350. I had replaced all factory speakers in the ES with Infinity reference series and added a JLAudio XD600v2 powering a 10"W6. Trying to figure out the best way to put the sub and amp in the GX
I plan to start a new build thread once I'm underway... Just need to clear up this wiring question!
#269
I am pretty sure there is not a 2-way crossover between the 4" and tweet, if you look at the pictures in the original post of this thread you will notice the factory tweeter has a capacitor attached to it. How are you planning to wire your system? I would suggest put your infinity crossover between the dash speaker and tweeter. Use your active crossover in the amp to run about 70-300 hertz to the 6x9's and 300 and up to the dash/tweets.
Peacebay (04-14-22)
#270
