DIY GX460 Stock Speaker Upgrade
#61
Thanks. I manage to install dash and front speakers this afternoon. Went with JBL GTO939 in the front. Just like dash, the mount holes doesn't align correctly. I had to drill a fourth hole on the adapter. Honestly, the included mounting screws doesn't look very secure. I was afraid the speaker would fall out when drive over a pothole so I put some fabricated metal retainer on the back and epoxy it with JB Weld. For some reason, I still don't think it is secure enough ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
but don't know what else I can do. How did you guys secure speaker to adapter? Did you just use metal screws on plastic?
i recall setting the screws at angle and center speaker fit very tight.
As about front door GTO939 - i don’t remember how exactly i fit them. But I do remember using drill and a Dremel and an original Screws and metal housings. No epoxy. The speakers still work fine and seating well - no any rattling sounds.
I wonder how you like a sound quality of this set.
psun786 (10-25-18)
#62
i installed absolutely the same set of dash and front door speakers. I soldered original connectors to the dash kenwwods and
#63
Sorry for the late post. I don't drive this car much so didn't check out the sound until a few days ago. I actually read your post and decided to follow your choice. Overall I am very happy with the outcome. The GTO939 output more base than I anticipated that I have to turn it down a notch in the setting. After the center and front upgrades, the rear felt somewhat lacking. Any good choice on the rear that matches GTO939?
I thought it will most likely require more then one try to get a right set from the sound standpoint and install rear speakers setup correctly. So I gave up on this task.
#64
Just some info I've found for anyone else who may be looking to do this. These speakers look like they may be plug and play, although they are a bit pricey.
https://www.crutchfield.com/p_091IS6...RoCwHsQAvD_BwE
I'm about to take ownership of a 2013 Base GX w/Navi w/o ML and I'm already researching what to do to enhance performance of the sound coming from the stereo. I definitely want to keep the factory look of the receiver but can installing a separate amp to power new aftermarket speakers help? Would anyone suggest swapping out all of the speakers or just the 3 fronts? Any advice would be greatly appreciated.
#65
Sorry I never posted an update!
So I spent 3 full days in the garage swapping speakers in and out, trying different combos, listening to different tracks over, and over, and over, and I ended up liking the sound of a lower end JBL line (GX302 in the dash, GX962 in the front doors, and GX602 in the rear doors) that I found on clearance locally. Spent less than $300 for 2 sets of 3", 1 set of 6.5", and 1 set of 6"x9"! They're last year's model (actually 2016 I think), but had a tad more efficiency than the replacement models (the GT7 stuff), meaning they'd make just a little better use of the meager power the stock system puts out.
Once I got everything installed and buttoned back up I was pretty confident with my decision. Highs were crystal clear, mids had a depth and range that was SEVERLY lacking from the stock speakers, and the bass from the 6x9s is enough to rattle the rear view mirror. VERY solid with zero distortion!
So why am I writing all this in past tense? Well, the 3" speakers for the dash didn't *quite* fit the stock speaker hole or the mounting holes, and instead of taking the time to make an adapter plate like I KNEW I should have, I just jammed them in there and hoped for the best. Well, shockingly, all 3 have now stopped working. LOL! Since they were on clearance I can't seem to find another set, so I'm back to the drawing board for the dash. I'll probably just get a set of the newer JBL line and make adapter plates for them, as I did really like the JBL sound signature they all had together.
Anyway, I'll try to be a little more active on here if anyone has any questions about my setup. Thanks again for the inspiration for the upgrade tecman!!! Replacing the speakers makes the stock system sound light years better than the factory setup. Now I just need a sub....![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#66
Hey guys, need some help... I HATE the speakers that i got with my car (non mark levinson with navi package) and I'm looking for some recommendations from anyone who did actually change their speakers. Theres too much distortion when I up the volume and its not clear how I would want it to be (Even after playing with equalizer) Has anyone changed their speakers on their GX460 2014 and up ? If so what did you do and did it help?
#67
I just ordered these at best buy, but I'm worried only because of the fact that I'm not installing them myself lol
For Dash 3 I got Kenwood KFC-1066R
front speakers i ordered KFC-69
back speakers KFC-P71
best buy swore by kenwood but I was just looking to see for other options but according to your thread you seemed to be happy with kenwood dash so I'm happy to hear that, just wondering how the front and back speakers are gonna be......
#69
From another thread:
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/1385x740/screen_shot_2019_05_31_at_2_07_29_pm_e0aa87d0fa19038f468fcf700201c8ac0064a011_be55ddb8de795f4a4496a0e5d519e70e12c38657.png)
#70
Correct. All your bass is being sent through the headunit to the 6x9's in the door, along with mid and treble. Slapping a midbass driver in the door is going to result in poor audio quality IMO unless you have a way of blocking the mid and treble signals being sent to that speaker somehow. (snip)
Some questions for everyone: I understand there is a remote amp under the passenger seat, and that the radio itself does not directly drive the speakers - is that correct? Is it safe to assume there are line-level feeds from the Head Unit to this amp? Another "ES" thread indicates there are 2-pairs of shielded wires going to the amp (this suggests low-level line feeds, not speaker feeds). I'm betting that's the best place to tap in for an aftermarket system. ES - Shielded Connections from Radio to Amp Is this true for 2nd gen GX?
Then post-amp, can you confirm the front doors get a full-range signal form the stock radio? I'll be tapping off for a connection to an Alpine PXAE-0850S DSP with external amps, and just want a stereo L/R full-range signal to tap into. All F/R fading and processing will happen at the DSP. I'm hoping to avoid the need to re-combine both the front-door and dash speaker connections to get a true full-range signal (possible with my DSP, but very sloppy).
FWIW - The DSP has lossless BlueTooth - so my primary sound source will be my iPhone direct to DSP - bypassing the stock radio 100%. But I still want the option for FM and just to have the stock radio available on an alternate DSP input...
I'll be actively amping the entire system (3-way active fronts + active subs - 4048 Watts total), but I am still curious where the high-pass filtering is handled for the stock dash speakers. I'd assume at the external amp. I see the stock tweet has the capacitor integrated into it - but the dash mids don't. Kind of a moot point in my scenario - but my curiosity is piqued anyway...
Thanks - and Toodles
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Ncan8 (08-17-19)
#72
Anyone else upgrade their speakers? Thinking about doing this in the near future. Can anyone comment on the speaker type that is needed for dash and doors? i.e. 2-way, 3-way, etc? For the center dash speaker, are you guys using the same speakers as the side dash speakers? So basically end up with 1 extra speaker?
#73
Did you ever get a reply to this? I'm in the process of changing dash speakers. I was planning to use Infinity REF3022CFX on the sides and 1 JBL GX302 in the center. Can anyone confirm this is a good set up or not? thanks all.
#74
Nope... as you can see, no response. I haven't taken the plunge yet either. I am in no hurry though.
#75
I am interested as well. I want to basically switch out the 3 dash speakers with the best sounding and fitting speakers. Read this entire thread twice and it’s very informative but just need a a dummied down version so I can just order the 3 speakers and I won’t need adapters as I’ll just cut/splice wires(OEM speakers suck anyway, not worth keeping). I def would like to stick with the same name and series and I’m currently leaning towards Kenwood or Alpine.
