Seat Comfort - Questions, Problems, Options
#122
I just ordered a set of these: Front Seat Jackers from Desert Does It....someone on one of the other forums recommended them. SImple bolt on but the change in angle is supposed to help quite a bit. Might actually be the first mod I am doing before hzhao ;-)
nuclearn8 (08-17-21)
#123
thanks for sharing
#125
#126
New '17 GX owner, just to add my own experience, I think I had the same problem as several people in this thread. No matter where I would position the seat I would end up with a lower back ache after ever a short drive. Following rmtannerjr's guide in this thread and the PDF instructions for removing the seat back in this thread, I was able to disconnect the active head rest cable from the lower seat assembly. Taking the tension off that lower assembly made a HUGE difference in seat comfort to me, and lets me push the lumbar support out to a natural position, where before I had to keep it fully retracted.
Big thanks to rmtannerjr and hzhao for posting the info that helped me fix this problem
Piney1 (08-17-21)
#128
Easiest way to explain this is that (for me) it totally aligned my lower back/hip bone with the back of the seat. I felt immediate support where I used to have a "gap" between my lower back and the seat. I was also able to "lower" the front tilt of the seat so it no longer puts presser on my thighs.
Big road trip to the Bourbon trail in Mid-April so I will report back after that 9hr drive which will be the real test.
Cheap way for you guys to test this would be to remove the front seat bolts and prop up the front of the seat with some wood blocks. It won't be very stable but will give you an idea of the new seat angle before you make the investment.
Cheers.
Before Shot with WeatherTech Liner
Before Shot - note flush end cap on carpet
During shot - jackers add about two inches of lift
After shot with end cap - note gap between cap and carpet - looks a lot worse in the pic than in person
After shot - the lip of the weathertech liner covers the gap between carpet and cap in the front; side is still exposed but not too bad.
#129
https://desertdoesit.com/collections...-2009-4runners
I used this code for 10% off - CHLOEKUOTACO
WRD4chano (05-22-21)
#132
I’ve been contemplating some purple seat pads since we’re going to be driving back and forth between VA and TX at least twice the next 5 months… can use them working from home in our office chairs when not on the road trips… win win
#133
How was the road trip with these? I just installed a set in mine but haven't driven it yet. Super easy installation.
After logging two 8+ hr segments I did not experience either issue and was would not have hesitated to hop right back in the driver's seat.
The only issue that I did notice (and it probably wouldn't happen to anyone under 6' 1") is that the increased seat height has caused some reduced traffic light visibility. I do find myself dropping my head a bit to fully see traffic lights when I am first in line at a full stop but that is a small price to pay for the increased comfort.
Cheers!
#135
Got it.
Added in as "Seat Comfort / Uncomfortable"
https://www.clublexus.com/forums/gx-...calls-obd.html
