DIY 12v second row accessory power for the GX 460
#77
Looks clean indeed, but is located much too low IMO. They should have designed it much higher up or maybe even integrate it into the rear climate control panel.
The following 2 users liked this post by Chasin:
John00 (12-14-19),
SteveInCal (12-16-19)
#78
I like the OEM panel idea. I see the part is 58903-60880-c0. There is also -a0 and -e0, so I wonder if those are for other non-GX models? I know you said the harness is part of a larger harness, but does anyone know the part number for it?
captainnem (01-05-20)
#80
#81
Super Moderator
#82
Now we just need to figure out the part number for the wiring harness. It probably doesn't matter what vehicle the harness goes to, because I just need the connector, then I can splice the wires into + and -.
#83
Thanks - I referenced this for my GX470
Thanks for all the posts and photos, everyone. This helped me tremendously when I added an outlet to my first gen.
I posted photos of my mod in the GX470 forum in the hopes it helps others, too. Thanks again!!
~jb
~jb
#84
I'm attempting to add this as well, but I've already used the fuse the OP used for a front camera, and the only other one I can find that seems to work is the blank that's 4 above the one he used, but it's a constant on. My USB outlet has an LED ring that would always be on if I tapped power from that fuse, so that's no good. My other option is to tap into the front power outlet, but it blew its fuse as soon as I connected the two. So I guess I'm asking:
- Where else could I get power from?
- Did I connect to the front outlet incorrectly? Here's a picture - white/black stripe I assumed was negative, and green was positive?
Thanks!
Thanks!
#85
Thanks!
Thanks!
#87
Thanks!
Thanks!
**this is a random one on amazon not one necessarily meant for the vehicle
GB2011GX (04-22-20)
#88
#90
More power options added
Finally tackled this after adding in MTS.
Here are the items I added for more power options:
1) 2x 2.1Amp USB ports with a Voltage output reading to the left of the steering wheel.
2) 2x QC 3Amp ports behind the glove box along with a 12V outlet pulled from a 99 4Runner in a salvage yard.
3) 2x 12v outlets in 2nd row center console along with 2x 2.1Amp USB ports.
4) Ran additional wiring down passenger side foot scuff plates to add a 12v outlet in the rear later.
5) Used an add-a-fuse circuit tapped into the fuse box under the drivers side, all with 14gauge wire to all outlets/ pigtails for usb harness ports.
They will not all be used at once, so they are only fused to 10Amps. But I’m very happy with how they all came out, and I can monitor rig voltage now too. Also
it allowed me to get a nice quick change jaw crimper set and a lot of crimps/heat shrink to ensure a clean install.
2x 12v outlets and dual 2.1Amp USB ports.
This image was from upgrading to MTS, and prepping the glove box 12V outlet.
Of course new tools are always justified! 😀
