Spacers?
Old 06-19-15, 04:26 PM
  #31
tecman
tecman's Avatar
Originally Posted by GX460PREM
Side view of the 1.5" wheel adapters installed on 24" rims...
Show the rims
Old 06-19-15, 05:30 PM
  #32
GX460PREM
GX460PREM's Avatar
Originally Posted by tecman
Show the rims
Per request...
Old 09-19-15, 07:46 PM
  #33
ksu1998
ksu1998's Avatar
just put some meat on the rims
Old 09-22-15, 12:20 PM
  #34
GoHuskers
GoHuskers's Avatar
Any rubbings/trimming required on your 275/65/18? Thanks.
Old 11-02-15, 10:58 AM
  #35
daman7676
daman7676's Avatar
I'm also curious if there's any rubbing? ksu1998, can you comment? Thanks
Old 11-02-15, 11:32 AM
  #36
ksu1998
ksu1998's Avatar
i have toyo open country at
it will squeak(rub) on driveway entry and will rub some when you take these off road, but I will do the same tire as long as I have this truck
thank me when you pull out your friends if you ever deal with mud or snow.
Old 01-23-18, 02:48 PM
  #37
GoHuskers
GoHuskers's Avatar
Bring back the OLD thread...
How are the spacers doing? Do they hold up well? Thank You.
Old 01-23-18, 02:53 PM
  #38
tecman
tecman's Avatar
Haven't had a wheel fall of of mine yet
Old 03-23-18, 08:32 AM
  #39
GoHuskers
GoHuskers's Avatar
@Tecman - what is the brand of your wheel adapters? Thanks.
Old 03-23-18, 10:01 AM
  #40
tecman
tecman's Avatar
I bought them on eBay I don’t recall if the seller even mentioned a name.
Old 03-23-18, 10:45 AM
  #41
bbqsoup
bbqsoup's Avatar
Tecman, did you have to replace the spare with the same size too?
Old 03-23-18, 11:18 AM
  #42
tecman
tecman's Avatar
Not sure what you mean bbq. The spacer bolts to the rotor and then the wheel bolts to the spacer (no bolt pattern changes). Also I don't have a spare with my modified exhaust.
Old 03-23-18, 11:23 AM
  #43
bbqsoup
bbqsoup's Avatar
Sorry, I meant when you swapped for 20" do you keep your 18" rims and tires or swapped for the same 20" rims too?
Old 03-23-18, 11:30 AM
  #44
tecman
tecman's Avatar
Five 18" wheels with tires are in my basement.
Old 03-23-18, 02:12 PM
  #45
GoHuskers
GoHuskers's Avatar
@Tecman
You have the 1.25" so does the original lug flush with the surface of the adapter? In another word - did you have to cut/trim your original lugs?
Quick Reply: Spacers?
