ISCjonny's 2015 GX460 Few Simple Upgrades...
http://www.prestigioussociety.com/?page_id=1167
http://www.beatsonicusa.com/nav-dvd-...ota-lexus.html
Quick Update...
Tinted all the windows. 28% Solargard Quantum all around including sunroof & 52% Solargard Quantum on the front windshield. Just for reference, having film placed on the front windshield and sunroof makes a huge difference for the inside temperature of the car compared to just getting the side and back windows tinted. Even if you get 70% film (pretty much clear) for the front windshield, it'll make a big difference by blocking the UV and some of the solar energy (heat).
Also installed a BeatSonic AVC38 RCA input wire harness. Plug and play into the back of the headunit. Connected the RCA (R/W/Y) to a and custom mounted it into the little compartment next to the USB/12V plugs. Also purchased a and tapped it into the back of the 12V Cigg adapter to power the HDMI to AV Converter. If you install exactly how i did, you will also need a right angle adapter for the mini USB. Otherwise the straight USB plug hits the factory USB/AV module.
Now you can stream anything with a HDMI signal to the NAV screen. For my family, we all have iphone's. So you will also need a Lightning to HDMI adapter. If you use this adapter and also want to charge your phone at the same time, do NOT plug the Lightning Cable into the factory USB ports. I don't know if the USB ports don't have enough power to charge and power the HDMI signal at the same time or if the headunit gets confused with the multiple input signals, but the nav screen will keep turning off and on and end up rebooting once you remove the USB cable. Buy a USB car charger plug for the 12V Cigg adapter.
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/ED4F9FA8-550B-4CFB-B9D1-AAA736048266_zpsuwzrnfqp.jpg)
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/CF373289-5A71-48A9-88E6-CC6A7229A08F_zpsabuk6tjh.jpg)
Words of advice, if you decide to stream movies from your phone, you will burn thru your data very quickly. LOL. My wife has been streaming netflix whenever i drive, and she has already went thru 10GB of data within 8 days. Now I'm debating on getting a dedicated MiFi unit for the car and hooking it up to an AppleTV to save my mobile data plan.
Finally.... Goodies from Japan arrived today. I will update again once everything is installed.
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/9289CB29-7A1B-4528-ADBF-C6E1D84DD409_zpsoqi7kskh.jpg)
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/6A424F49-3224-4787-9F1F-6919F802172D_zpsyf1n03kq.jpg)
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/9639E433-8C9F-48A2-96FF-0A06D33CF010_zpsg75csdsa.jpg)
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/65795842-7B26-489A-A160-174104F44432_zpszgtsodqi.jpg)
Quick Update...
Also installed a BeatSonic AVC38 RCA input wire harness. Plug and play into the back of the headunit. Connected the RCA (R/W/Y) to a HDMI to AV Converter and custom mounted it into the little compartment next to the USB/12V plugs. Also purchased a 12V to 5V step down mini USB and tapped it into the back of the 12V Cigg adapter to power the HDMI to AV Converter. If you install exactly how i did, you will also need a right angle adapter for the mini USB. Otherwise the straight USB plug hits the factory USB/AV module.
ISCJonny...
Don't know if you've RSES on your '15 GX460? Just want to find out if using the BeatSonic AVC38, are you able to view HDMI content from the main NAVI screen to the rear headrest monitors similar to operating in DVD mode?
I believe there is already a RCA input accessible from the 2nd row. Does this input go directly to the rear seat monitors or does it display on the main nav screen as well?
No idea. Unfortunately i dont have RSES. I originally wanted it, but i was told it was special order only option and i would have to wait 3+ months for it.
I'm using an iVic 6DR in my GX460 but trying to figure a solution to mirror HDMI video sources from the Main NAVI screen to the RSES. So far, I have been unsuccessful with different attempts.
I did come across your BeatSonic AVC38, but technical support couldn't confirm on the functionality of the RSES so I didn't buy it.
Picked up the 2015 GX460 Luxury w/ ML a few weeks ago. Just wanted to share a few simple upgrades i have already done.
Prestigious Society Nav/DVD Override Module. Installation was straight forward. Took less than 20 minutes to complete. Simple - , - , + , + volume combination to activate override.
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/0088C184-5ED4-44AC-9A03-A83DB2E7D15D_zpshe1oz45p.jpg)
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/BD74B877-8434-4716-A566-91C16C224760_zpsejxsnfd6.jpg)
Swapped out the halogen puddle lights to 15SMD Board LEDs (the standard 5SMD led bulb was not bright enough for me). This was a bit more tricky since the housing technically cannot plug and play the 15SMD LED Boards. Took a closer look and noticed the clear lens was hot melted into the black plastic backing. So i took a flat head screwdriver and carefully broke the hot melt all the way around and separated the 2 pieces. Surprisingly, the 15SMD board fit perfectly in the cutout. Due to the limited space between the LED board and the backing piece, the adapter plug for the 15SMD LED board could not be used. So i ended up tapping the 2 wires directly to the oem plug contacts.
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/BC95B067-CA03-48D7-816A-1ADEA515BDEE_zpshrmxjnvp.jpg)
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/9351F414-11CE-4BA5-BCF9-BE0BCFA5B60E_zps1hsxddng.jpg)
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/E0938FC8-B67E-4218-91CF-63B5A83FB73D_zpsghvep3cw.jpg)
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/E3F0E35E-1D5D-4141-9933-99441533B357_zpsqcpfwc1v.jpg)
Replaced the 6 dome lights using the 15SMD Board LEDs and the 4 door lens using 4SMD Flank LEDs.
![](http://i257.photobucket.com/albums/hh219/is350jonny/2015%20GX460/CCA655F7-6154-49D5-B6B0-3DF915E9E46F_zpszj76ycor.jpg)
Looking to get the windows tinted in the next week or two while i wait for a couple parts from Japan to arrive. Ordered TRD Real Carbon Fiber Pillar Overlays and JDM OEM Window Visors. Should be here in about a month. I'll give another update once those parts arrive and i install them.
Debating if i should change the wheels to the 2014 GX460 FSport Wheels and call it a day or save up for a legit aftermarket setup. What do you guys think?
SilentWish
09-01-10 01:19 PM
