Did you finished this project? Thinking about purchasing a hard shell roof top tent and I doubt it's going to clear the shark antenna with factory rails and cross bar.
I ended up ordering the racks from Fenza (miami based after-market auto accessories vendor). https://www.fenzausa.com/
They are supposed to arrive today, so haven't tested/installed them yet to ensure they fit. If you are thinking about putting a roof-top tent, you'll probably want something heavier duty that can distribute the weight better. Etrailer sells a 3 bar system from Rhino Rack that bolts directly to the roof (after removing the factory rails), if you don't want a full platform rack.
There are others that I'm sure folks on this forum or check out the GXOR (GX OffRoad) forum on facebook.
Copy. The hard shell roof top tents I was looking at all state that a cross bar is all that's needed since it just clamps on top of it. I did look at that platform rack but most like additional accessories will be needed. The simple the better
Chris, did they fit your GX? The Fenza site shows the rails for 2014-2019 Toyota Prado FJ. Mine is a 2013, so I'm hoping to confirm before ordering. Thanks.
They just arrived and I did a quick look to see if they should fit but haven't had time to install them (and it's pouring buckets outside). They also didn't come with any instructions. I think I can probably figure it out, but has anyone else on the forum who's installed the Prado racks on a GX460 found a parts diagram or installation instructions? They are probably the same as the instructions for the factory GX470 rails as well. Any instruction manual, exploding parts diagram or even better video would be awesome.
Otherwise, I'll hack my way through it and let you know if they fit and how it goes.
If you got all the hardware that "Jacket" showed in his original post, you should be good to go. Those rails really look like what Lexus should have installed on our rigs from the factory. I am doing a big road trip out west, so I need to haul some gear on the roof. Trying to figure out the best way to go. Thanks for your info.
I came across the Fenza Prado rails on my own a few weeks ago. I mentioned them elsewhere on here because for some reason I didn’t see your post. In any event, have you installed them yet? If so, do you recommend? I am just looking to haul a Yakima RocketBox cargo carrier. Thanks!
I just installed the Fenza racks this week. They worked out and look great. I had a couple of minor issues installing them.
1) The middle brackets weren't quite the exact fit. I had to drill the holes a little bigger b/c they were 2-3mm too close together. Then they were a really tight fit to bolt in and I broke off a bolt ratcheting it in. I ended up buying replacement brackets separately from a sight in the United Arab Emirates that fit correctly. They were $3 / each and $20 in shipping.
2) The plastic covers (particularly the middle ones) have little tabs that can break easily, so be careful installing them.
The bars look great and seem MUCH sturdier and more useful to attach stronger cross bars. I have Whispbar cross-bars and put a rocket box, ski racks and Rocky-mount bike racks on them.
Good luck!
-chris
Thanks for the update, Chris. Looks like the Fenza option is ok.
Good luck!
-chris
Great to hear. Do you by chance have the UAE website and part number for the bracket? Also, did you need to use any silicone sealant on bolts?
I recently purchased a hard shell rooftop tent from Tentbox and have run into issues clearing the sharkfin antenna. I currently have OEM Lexus rails and they sit very low. Have you discovered a solution yet? I'm close to buying a set of Rhino bars RVP23. They require that the factory rails be removed, and I'm concerned that they will not be tall enough to clear the shark fin when mounted directly to the roof. Anyone have any thoughts?
So to make sure that I understand correctly, I can in stall 470 raised roof rails on my 2010 460? If thats the case, time to start hunting down some of those!
Wanted to drop in and say thanks to this guide. I followed this guide for tips on adding silicone to the tower bolts and used the codes for the molding roof trays to complete my 3 aero bar install. Btw, the cost for the roof molding was pretty expensive for 4 pieces of rubber.
I chose the 3 bar setup for my needs in wanting the widest spread for carrying my 21' long canoes. The middle bar would be used for a cargo box for winter sports.
I installed a 4Runner roof rack on my 460, it fits almost 100% and provides a much better platform than OEM
I did the same last weekend. One thing I didn't expect: The 4Runner cross bars will not fit. Also, the gap between the rails is not consistent; it's wider at the front and narrower at the back.
Can anyone with the Prado setup compare? Do the OEM crossbars work with the Prado rack?
