Enform Remote Start Problems and Questions
#137
my remote range is about 25 feet. with a new battery. i think its supposed to go up to 80 ft. i guess 25 is under the max of 80 so im good.
#138
Super Moderator
I can get range similar to what tecman shows in this video
tecman (11-15-19)
#139
i should have added i get that range from inside, through a window, through the metal screen, and facing the back of the gx.
i should try a test like in the video
it does work for how far i need
#140
My key fob works with 3X lock/hold but when I attempt to open driver side door, engine shuts off. Shouldn't door then open whithout engine shutting of as long as key is in my possession?
#141
Super Moderator
#142
Yes that's expected behavior according to some members here. I also didn't like it as my other cars would start and engine stays on while entering the car with key is in my possession
#144
#146
I paid much less than $600 installed, but I also have a good relationship with local installer. I have had great luck with compustar setups.
John00 (11-29-19)
#147
I just had a compustar setup installed in my 2014. 3x on the lock button on the oem fob starts the vehicle. I also have the drone mobile app for feedback, status and tracking of the vehicle. App allows vehicle to be started from anywhere. You have the option of a compustar fob. It will have longer range than oem fob, but you need to carry a second fob.
Currently, in my location, CarToys is selling the Compustar for $380 which includes a "basic" install. Yeah no thanks, I know they will try and gather as much money as they can from you on top of this package.
#148
Do you know what all is needed to complete the install? I see the compustar module on Amazon for $99 but it talks about it may need additional harness and a specific harness if the system is a low or high current. May need to do more research on my own to be confident but I would like to install this on my own. Since my vehicle is a 2016 model year, I unfortunately cannot just buy the OEM RES module.
I had "my guy" that I've used for 15 yrs do mine a month ago on my 2014. I paid more than $380, but I had an lte box installed to allow the use of their drone mobile app.
I got a month of premium service included with the install. On their black Friday deal, I renewed for 5 yrs for 2.99 a month for their basic service.
I'd check local facebook and forum pages to see if there is a recommended installer and talk to them about the specifics. This is my 4th compustar system. Each time they get better and better.
#149
I would like to have the same functionality as the remote start on my Highlander, but I understand that they went to an app based solution. My question is if I get the 12volt solutions kit will it work out of the box or do I have to bite the bullet and get the monthly Lexus subscription.
mcfancy
RX - 4th Gen (2016-2022)
09-07-16 07:42 AM
