Enform Remote Start Problems and Questions
Old 02-25-19, 08:13 AM
  #121
nitroracer
nitroracer's Avatar
Originally Posted by Acrad35751
Unless you go aftermarket '16+ has to use Lexus Enform Remote
https://drivers.lexus.com/lexusdrive.../enform/remote
Is this for the GX, only? I recently discovered that my '18 ISF has the key fob option (something that was never communicated to me several months ago at time of purchase). It also has the remote app.
nitroracer is online now
Old 02-25-19, 08:57 AM
  #122
GX763
GX763's Avatar
After buying our GX, we found there was a remote start added to it. press lock button twice, and on the third, hold it down to start. Only downfall is the system runs for only about 10minutes.
GX763 is offline
Old 06-03-19, 05:11 PM
  #123
LS460NYY
10th Gear
LS460NYY's Avatar
Default The remote start with enform
So I have a 2018 GX 460 and the enform just expired (May have been a post already,if so point me in the right direction)
now the lock lock lock feature to start doesn’t work. BYPASS??? Does one know of a bypass module or 3rd party starter that works?any help would be appreciated
LS460NYY is offline
Old 06-03-19, 06:57 PM
  #124
hzhao
hzhao's Avatar
For 2014 and earlier, there is a remote start ECU (non Enform dependent) available. I believe it is compatible with all the GX model year. Do a search on this forum, there is a discussion thread on the subject.
hzhao is offline
Old 06-05-19, 06:12 PM
  #125
LS460NYY
10th Gear
LS460NYY's Avatar
Thank you,much appreciated
LS460NYY is offline
Old 06-06-19, 05:46 AM
  #126
GX763
GX763's Avatar
I believe anything pre 2016 had the option of the non Enform remote start. MY15 has this feature
GX763 is offline
Old 06-10-19, 06:12 PM
  #127
brian4l
brian4l's Avatar
Press lock button twice on the FOB then hold down until the lights flash. Wa-la.
brian4l is offline
Old 06-11-19, 03:06 AM
  #128
LS460NYY
10th Gear
LS460NYY's Avatar
That did work until Enform shut off. Thought it would stay but no such luck
LS460NYY is offline
Old 07-04-19, 08:50 AM
  #129
MatB
MatB's Avatar
Default Remote start
I was wondering if anyone has had experience installing a remote start. Lexus part #PT39860151. My understanding is this is compatible with a smartphone from any distance. Any other parts necessary for installation or functionality? Any installation tips would be greatly appreciated. Thanks!
MatB is offline
Old 07-04-19, 09:09 AM
  #130
hzhao
hzhao's Avatar
For smart phone capable remote start for lexus, require Enfourm subscription from Lexus.
hzhao is offline
Old 11-11-19, 12:42 PM
  #131
rfcbuf
rfcbuf's Avatar
Default Key Fob Remote Engine Start
How do I get my key fob to remotely start engine? Had my dealer do it but dealer is 60 miles away to demo again. Just purchased new 2019 GX 460 with premium package but remote key start is not an added accessory. Dealer started car from 10 yards away and he is no magician.
rfcbuf is offline
Mistaken (11-11-19)
Old 11-11-19, 01:01 PM
  #132
Mistaken
Mistaken's Avatar
Click the lock function 3x.
Mistaken is offline
Old 11-11-19, 01:11 PM
  #133
Smokeyyank
Smokeyyank's Avatar
Does this work on all years?
Smokeyyank is offline
Old 11-11-19, 01:15 PM
  #134
Acrad
Super Moderator
Acrad's Avatar
Received 3,654 Likes on 2,392 Posts
You need RES or RES+ on '10-'15 model.
https://www.clublexus.com/forums/gx-...ine-start.html
For '16+ you need an Enform subscription
If '10-'15 and unsure if you have RES/RES+ and it doesn't work you can confirm with build info site
https://drivers.lexus.com/lexusdrive.../vehicle-specs
Acrad is offline
Old 11-14-19, 06:53 PM
  #135
angelslex
angelslex's Avatar
Click lock click lock and on the 3rd click hold till your lights flash and let go
angelslex is offline
Quick Reply: Enform Remote Start Problems and Questions
