PCV Valve Location
Old 12-10-15, 02:25 PM
Brn2drive
Brn2drive's Avatar
Lightbulb PCV Valve Location
I'm trying to knock out some quick maintenance items on a recently purchased GX. Does anyone know where the PCV valve is located? I looked all around the valve covers and can't seem to find it. Thanks!
Old 12-11-15, 11:16 AM
Jacket
Jacket's Avatar
I'm thinking it's 12204 in this picture, which would put it under the intake on the front of the block.
Old 12-11-15, 09:30 PM
Brn2drive
Brn2drive's Avatar
Originally Posted by Jacket
I'm thinking it's 12204 in this picture, which would put it under the intake manifold on the front of the block.
Thanks! That looks right, I'll check it out tomorrow and hopefully it's accessible without removing the intake manifold.
Old 12-14-15, 05:00 AM
NewB2Lexus
NewB2Lexus's Avatar
Do you have a particular problem or just want to give it a good cleaning with a few blasts?
Old 07-26-17, 12:23 AM
Acrad
Super Moderator
Acrad's Avatar
Received 3,656 Likes on 2,394 Posts
If one does replace this torque specs appear to be just 31 in-lbs
Old 07-26-17, 12:33 AM
Dallasguy1
Dallasguy1's Avatar
Why do we need to do this any symptoms we could look for ?
Old 07-26-17, 12:37 AM
Acrad
Super Moderator
Acrad's Avatar
This is a pretty good overview
https://axleaddict.com/auto-repair/H...PCV-valve-test
Realistically probably doesn't need to be changed until 100K miles or more. I ordered one for around $10 and plan to swap mine out. I'm just OC maintenance-wise. :-) I think I saw posted you use a 23MM deep well socket. It's just plastic so it should extract fairly easily. It could cause oil leaks if it ever gets plugged but you would probably be seeing a CEL as well.
Old 07-26-17, 05:51 AM
NewB2Lexus
NewB2Lexus's Avatar
Even if you do not have any symptoms it is plastic and it ages. If you wait too long and you need to remove it, a brittle plastic part may break and pieces may fall inside the block. If this happens your engine is at risk of a complete failure (unlikely though). Usually it costs $10-$20, it is wise to replace it once you hit the 8-10 years mark regardless.
Old 07-26-17, 01:56 PM
Acrad
Super Moderator
Acrad's Avatar
Very true.... I need to change it again on another vehicle of mine as well.
Old 08-09-17, 03:47 PM
Acrad
Super Moderator
Acrad's Avatar
Part came in a few days ago... I'll probably replace after I do my oil change.
Old 08-10-17, 01:47 PM
Acrad
Super Moderator
Acrad's Avatar
EDIT: FSM does showing intake manifold being removed.
I was looking at this last night and was gonna change it but after taking a few parts out I backed out. I believe recommended procedure is to pull the top air plenum off but a few Tundra reports just getting the foam out and pull the outer skirt layer off the hose. The tearing of the foam is what gave me pause. I got it back together and can't really tell anything is abnormal down there. I can see why air plenum piece is recommended as I can't see a way to get the foam out as-is without tearing. I'll revisit this another day. The valve is quite a ways down in there so you may want to have some long reach needle nose pliers to extract it out.
Closest video I have found is this and it only really shows where it is at. Engine parts are not fully the same either. This might be a 5.7L and far more room with fewer engine pieces within engine in video versus the 4.6L we have.
Old 08-18-18, 01:08 PM
Acrad
Super Moderator
Acrad's Avatar
Old 09-21-19, 06:24 AM
Acrad
Super Moderator
Acrad's Avatar
5.7L but looks like it can be done far easier than FSM would suggest.
Old 11-25-19, 07:12 AM
Rufio
Rufio's Avatar
Did anyone end up doing this? I’ve got a 2013 with 90k on it so not super worried about it since I don’t think it’s in the manual. I need to have my SAP recall done so I was thinking I might drop off a PCV with it and have the dealer put it on.
Old 11-25-19, 09:26 AM
Jacket
Jacket's Avatar
I just did it on a V6 RAV4. Does that count? It's a metal valve on the RAV, so I just cleaned it up and reinstalled.
The air plenum did need to come out, along with the throttle body and part of the intake hose. Took a couple hours, but I was also doing spark plugs and a coil pack.
Quick Reply: PCV Valve Location
