The REARS ... just have the car running ... and have someone gently push the brake pedal ... the pump will push fluid thru the system ... so simply bleed until no bubbles / clean fluid emerges ... no need for "pumping" and opening / closing the bleeder valve(s) per the traditional procedure. As per standard ... Right-Rear ... then Left-Rear ... then ...
The FRONTS ... bleed without the without the engine running ... and the do the traditional bleeding procedure ... opening and closing the bleeder valve with each brake pedal up-down "cycle" ... using a helper in the driver's seat. Right-Front ... then Left-Front ...
When doing the REARS ... keep a very close eye on the brake fluid level ... the pump moves lots of fluid ... one does not want to introduce air into the system.
I finished up my complete OEM brake replacement (rotors/pads/hardware) with the Motive power flush this morning. It all went well as I had hoped. The rear fluid actually looked a little dirty compared to the fronts. Now that that I have done this on this vehicle I won't think twice about doing it in the future at factory recommended intervals. It was really easy with the wheels offs. I will make sure it coincides with a summer/winter wheel swap.
This cap mentioned many times previously in thread works great for pressure bleeding/flush
"Power Probe BA10 Small Adapter for Toyota is a small adapter that fits Toyota and Lexus master cylinders with diameters of 1.65–1.83 inches. It features an expandable O-ring for a leak-free seal, 3 tab cam locks, and a 360 degree swivel automotive style air hose nipple. The BA10 is also color coded red to identify it as a Toyota brake adapter"
Looks like it went up another $25 since 2019 when I purchased it
... love tools ... but never understood the need ... with an extra person pumping the brake pedal, brake fluid flushing is easy ... end result is no different ...
This really is an easy service no matter how you plan to do it... 2 person, vacuum, or pressure...I'll admit I was a little intimated by the electro/hydraulic brake unit unlike setup in any other car I've owned and wanting to ensure I did the job right.
Next up... due for another drain and fill on the AT this summer. It's been about 30k miles.
