View Poll Results: Best 22 inch tire for 2014 plus GX460
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Official GX Tire/Wheel Thread
#1636
Do you guys agree with ChatGPT's comparison of these tires?
The Cooper Discoverer AT3 4S, Falken WILDPEAK A/T3W, and Hankook Dynapro AT2 RF11 are all excellent all-terrain tires that offer a combination of on-road comfort and off-road capability. Here are some key differences between these tire models:
- Tread Design: The Cooper Discoverer AT3 4S has a hybrid tread design that provides good on-road handling and traction, as well as off-road performance. The Falken WILDPEAK A/T3W has a more aggressive tread pattern that provides excellent off-road traction and handling. The Hankook Dynapro AT2 RF11 has a symmetrical tread design that provides good on-road performance and a quiet ride, as well as off-road traction.
- Tread Life: All three tires are designed to offer long-lasting tread life, but the Falken WILDPEAK A/T3W is often considered to have the longest lifespan due to its tough construction and more durable tread compound.
- Ride Comfort: The Hankook Dynapro AT2 RF11 is designed with a focus on on-road comfort and provides a smooth, quiet ride. The Cooper Discoverer AT3 4S and Falken WILDPEAK A/T3W can feel a bit rougher on paved roads due to their more aggressive tread patterns and stiffer construction.
- Off-Road Performance: The Falken WILDPEAK A/T3W is designed to provide excellent off-road performance and traction in challenging conditions, while the Cooper Discoverer AT3 4S and Hankook Dynapro AT2 RF11 are still capable off-road, but are better suited for more moderate terrain.
- Snow Traction: All three tires are winter rated and provide good traction in snow and icy conditions.
- Price: The Cooper Discoverer AT3 4S and Hankook Dynapro AT2 RF11 are often considered to be more affordable options, while the Falken WILDPEAK A/T3W can be priced higher due to its more advanced features and construction.
#1637
I’m investigating wheels a bit.
if I’m reading correctly 17x7 or 17x7.5 seem to fit with 275 /65 / 17 - no rubbing. does this sound accurate?
this all gets a bit confusing.
#1638
if you look above at https://www.clublexus.com/forums/mem...-bflanary.html looks like you have to work on fender liners. I have 31.5" (265/65R18s) and they don't rub at all. I think you should look at the tire diameter. If you're going to spend on fat tires, you probably should be looking at some type of lift.
265/65R18s with no lift
Another view pre-lift
DeeDeeRX (04-30-23)
#1639
you might also read through this great thread started by Schwein about various tire sizes on stock wheels and without lifts: https://www.clublexus.com/forums/gx-...on-thread.html
pacnwatx (09-09-23)
#1641
17x8 ET+25 Clearance
Are there any clearance issues with the wheel and the front suspension if I put in a 17x8 ET+25 wheel? I'm not concerned about tire clearance, I'm concerned about wheel to front suspension clearance. The stock wheel is 18x7.5 ET+25 and going to a 17x8 ET+25 will bring the rim's upper inner surface 1/2 inch lower and 1/4 inch closer to the suspension. Is there enough clearance in there to allow for that?
#1642
My tires are 285/70-17. ~ 32.7" diameter.
Largest diameter spare in the OEM spare location, with the Curt #13043 Class III trailer hitch?
I am using a fully inflated 245/75-17 tire, which is ~ 31.5" diameter.
{The 265/70-17 (31.6") would not fit easily.}
Roughly an 1.2" diameter difference. 3.7%
about ~ 0.6" radius.
~24 revs a mile difference.
Should be ok for a temp use
2eXceL (05-25-24)
The following 3 users liked this post by jdam:
#1644
Can someone help me with this. Will these fit my 2017. No lift. My concern was the offset. I’ve tried to order from my local but somehow they want 299$ a wheel. Same wheel. I also get points from work to put towards Amazon and eBay gift cards.
https://www.ebay.com/itm/25510830590...mis&media=COPY
I like the wildpeaks but don’t want to rub. Any recommendations are welcomed.
thanks
thanks
#1645
thanks
thanks
#1646
I've got a 2019 GX and recently put some TRD wheels with LT265 /70 R17 K02's on it.
There was rubbing both sides, front and rear fender liners. I've massaged the rear fender liners back with a heat gun and those are taken care of. What's the typical method of moving/pulling the fronts forward some? I'm not interested in the ghetto tie wraps and eye bolt kind of thing either. I've got some time this weekend and I'd like to get rid of the rubbing issue once and for all.
Sorry for the poor pic. It was a (typical) sloppy, snowy, gloomy winter day in MN.
Thanks.
Thanks.
#1647
Method mr318 gloss black 18x9j offset18 with geolander G015 stock size tires did add a tiny more rolling resistance, but the ride quality and the looks are a big improvement compare to stock Bridgestone imo. I was surprised that the steering wheel not centered problem is also got improved. Overall I’m happy with this combination.
The following 6 users liked this post by nekoni:
blackangus (04-09-23),
nyctfl (06-04-23),
SCOFF82 (12-16-23),
sekr8squrl (04-09-23),
Shawn1234 (10-07-23),
and 1 others liked this post.
