View Poll Results: Best 22 inch tire for 2014 plus GX460
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Official GX Tire/Wheel Thread
#407
Wheel Offset.
I spotted used winter Wheels (265/60/R18) for my 2017 Lexus GX (premium) with following spec:
Bolt Patterns: 135x6, 139.7x6
Offset: +15
The Kal tire web site sates that it will fit on my vehicle, just wondering if the offset +15 will make any difference?
Offset: +15
#408
It will fit but it's wider and push out more to the fender - the stock offset is around +52-55mm I think, +15mm means you're going negative.
It'll have a wide stance... a bit more stable doing corner.
ayaz99 (09-28-18)
#409
#411
GX 460 Premium (2018) 20 Inch Rims
Hi there,
I'm new to the site and forum. I looked around on here about 20 inch rims. I recently ordered 20 inch Black Rhino Traverse rims and 285, 50, r20 Nitto G2 tires. I went to put them on today and there was a slight rub on the inside fender where the front tires are. Particularly, it rubbed on the inside, back bolt.
Has anybody else had the same issue running these tires or other tires this size: 285, 50, r20. I wanted a slight offload tire like the G2s. Any advise on running 20 inch rims on this vehicle would be greatly appreciated.
#413
There are a couple of threads here mentioning the Bolt rubbing when using bigger tires. Best solution is to either shave the bolt or get rid of it. It only holds the mud flap in place I think. There are two bolts that do that and one can do the as easily.
#414
17” Envy rims with 265/70/17 General Grabber
Ended up with a set of these...similar in design to the TRD rims. With 0 offset and the tires being almost 32” tall I needed to spend some time with the heat gun. In retrospect, wish I would have gone black...the gunmetal is too close to the color of my truck. It looks like I tried to match it, but failed. 😬
Today will be the last day I have them mounted. With 10cm of snow coming tomorrow I need to put on the blizzaks and factory rims.
bbqsoup (11-07-18)
DBLex1 (08-31-19)
#416
#417
bbqsoup (05-28-20)
#420
