View Poll Results: Best 22 inch tire for 2014 plus GX460
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Official GX Tire/Wheel Thread
#421
#422
The offset and backspace are different. If anything they will push out to the fender more than stock.
If you keep oem tire size specs you should be good. There are alot of gx470 and 460 running 4runner wheels, especially Gen4 and Gen5.
swampdawg (07-20-24)
#423
That's cool, thanks! It's either used 4Runner wheels or brand new aftermarket from tire rack.com
#425
Synergy001 (05-11-20)
#426
IanB2 (02-15-21)
#428
#429
Do you need hubcentric rings with the Lexus? If so, who makes them? My wheels won’t be stateside til December and I don’t know what day either.
#430
in my opinion, its needed..you should ask your vendor to include them. Hub sizing for the GX is 106 and the Volks are 112 so there is a size variance there.
Alexrod7 (08-22-19)
#431
I like that set up, was wondering if you did a +30 offset, then spacers any reason you didn't just do a 0 offset or something along those lines and no spacers? Also I really want the 275/55 set up, can you fit it without much rubbing on stock? I don't mind to trim a little but don't want to lift. seems like theres a lot of 285/50-20 but wanted to check how the 275/55 fits? thanks. Also how much spacer? essentially a +30 with .75-1" spacer is close to a 0 offset or -10 i think. Anyhow nice look. Thanks, Chris
#432
#433
Tire size?
I have my eye on some Mickey Thompson wheels size 20x9 with an 18mm offset. I would like to pair the wheels with some nitto Terra grappler G2 tires. Im wondering if I can run 265/50/20 or 265/60/20?
I dont want want to use spacers and I don’t want any rubbing but also want to fill the wheel well as best as I can.
Thanks in advance.
Thanks in advance.
#434
Thanks to this thread, I purchased a set of 20" Black Rhino Traverse wheels for my wife's newly purchased GX. Does anyone know the size of the center caps or where I could purchase blank black center caps or black Lexus center caps that would fit?
