View Poll Results: Best 22 inch tire for 2014 plus GX460
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Official GX Tire/Wheel Thread
bbqsoup (10-23-19)
#681
#685
The following 4 users liked this post by Mistaken:
#687
LIFT? Vossen hf6-1 22x9.5 in Yokohama parada 285/40/r22
Hello experts:
Could you please suggest if for this set Vossen hf6-1 22x9.5 in Yokohama parada 285/40/r22 posted in this thread I would need a major lift? What about Vossen hf6-1 20x9.5?
Mistaken (10-31-19)
#688
the wheel offset has a lot to do with the fitment. Also, try willtheyfit.com to see how different wheel & tire sizes and specs will affect fitment.
#690
https://www.willtheyfit.com/index.ph...=9-5&offset2=0
The 285/40/22 is only 11mm taller than the factory tire size of 265/60/18, so the 1.5% change in height isn't the concern. Concerning height, that tire will fit.
Concerning width, here in lies the issue. The 9.5" wide wheel on 0mm offset pushes the tire out nearly 2" from the suspension while maintaining a similar distance on the inside of the wheel/tire. It shouldn't rub any suspension components (i.e. the UCAs), but you'll definitely be into the wheel well plastics, and maybe the body mount.
Philly01 (11-01-19)
