View Poll Results: Best 22 inch tire for 2014 plus GX460
285 40 22
50.00%
285 45 22
50.00%
265 40 22
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Official GX Tire/Wheel Thread
Old 06-22-20, 03:40 PM
  #991
leftyguns
leftyguns's Avatar
Originally Posted by CaptRog21
Quick question. I put 265/70/18 Wildpeaks on my '17 about a month ago and made sure to do the fender liner mod before hand to ensure no rubbing, which worked out perfectly. However, I just got around to doing an alignment and the passenger side front tire rubs pretty bad on the UCA in reverse. I am only turning the wheel maybe 50% before it starts rubbing. Before the alignment, I could crank it 100% and have zero rub. Did they mess something up with the alignment??
messed something up by probably putting it back in-line. My stock UCA's had some nice shiny spots when I finally removed them from rubbing using the same tire size.
Old 06-22-20, 04:39 PM
  #992
CaptRog21
CaptRog21's Avatar
Good to know. Did switching to the aftermarket UCA correct the issue? Ended up ordering the Ironman kit due to the sale going on and will be getting new UCA with the kit.
Old 06-22-20, 04:57 PM
  #993
leftyguns
leftyguns's Avatar
it fixed it for me yep. I have the SPCs and no rubbing at all
Old 06-23-20, 11:00 PM
  #994
CaptRog21
CaptRog21's Avatar
Good to know. Hopefully I will have the same result with the Ironman UCAs
Old 06-25-20, 09:24 AM
  #995
4les
4les's Avatar
Default Ltxat2
Does anyone have these tires on the gx. Michelin atx at2. I don't plan to lift the vehicle. Mostly on road and light trails.
https://www.michelinman.com/tires/ltx/ltx-a-t-2.html. A 275 widhth?
LT275/65R18/E 123/120R LRE
03822
Old 06-29-20, 05:03 PM
  #996
louscrw
louscrw's Avatar
I ordered a set of BC Forged wheels today and paid the 50% deposit. I should have the drawings tomorrow. The “drawings” will show me the lip size, concavity, etc. to ensure I’m happy with the look. Typically 3-5 weeks for delivery. We’ll see. I was seriously looking at Gram Lights; however, I wanted a wheel that was hubcentric (even though plenty of people told me they have zero issues with the larger bore).
I ordered the LE72 (2 piece forged) model in 18x9ET0 fitment. I chose the Brushed Dark Black finish for both the lip and center section with exposed Titanium hardware. The brushed finish is awesome looking. If you’ve never looked at BC Forged wheels, you should check them out. Lots of designs and wheel finishes and made to order specifically to your desired specs.
Here is a pic of the style I went with:
The following 3 users liked this post by louscrw:
2chains (06-29-20), MarkVII (06-29-20), msgs350 (06-30-20)
Old 06-30-20, 07:34 AM
  #997
Grizzld
Grizzld's Avatar
Default Gx 460 with Fuel D670 wheels
2017 GX460 with 20x9 Fuel D670s, 1mm offset, 275/55 R20 Venom Power Terra Hunter tires. There was quite a bit of rubbing that took about an hour to fix using a heat gun and basic tools, no cutting at all.
Got super lucky finding them on Craigslist for $1400, very lightly used with tires.
Old 07-01-20, 10:47 AM
  #998
2chains
2chains's Avatar
Looking forward to the pics! What tire size are you going with and where will the 0 ET put you at the fender wells?
Old 07-01-20, 01:46 PM
  #999
louscrw
louscrw's Avatar
I already have 265/65/18 Wildpeaks mounted on the OEM wheels. I chose 18x9ET0 bc that is the size people with Volk/Rays went with, so it should put me flush, maybe a tad outside. We’ll see. Notified today the wheel design got sent to production and they should be ready to ship in 3-5 weeks
Here is the drawing. Looks like I’ll have a 67.7mm (2.665”) lip
Old 07-04-20, 06:14 AM
  #1000
2chains
2chains's Avatar
^^Looks like great specs on those rims. That +2 1/2" lip will be sic to see!
Old 07-10-20, 01:30 PM
  #1001
tonyjh63
tonyjh63's Avatar
Default Tire pressure?
What tire pressure does everyone run on their trucks? I know the door jam says 32 psi...
i just bought a new set of tires (Michelin Defender LTX M/S, 265/60/18), and felt a noticeable improvement in the ride and handling (it had some fairly worn Goodyear Wranglers on before). What surprised me is that when I checked the pressure in the tires, the shop had set them all to 40 psi (sidewall reads a maximum of 44 psi). I can imagine the truck would ride even smoother if I dropped the pressure down to the Lexus recommended 32 psi...
Anyone else run their tires above the recommended pressure?
Old 07-10-20, 02:06 PM
  #1002
Romanova
Romanova's Avatar
Running the same tires and I run them at 32 PSI. Perfect ride quality at that pressure.
Philly01 (07-10-20)
Old 07-16-20, 04:24 PM
  #1003
whododat
whododat's Avatar
Default One more tire question
For those that have installed a Dobinson medium suspension and UCA's on a 2015, what size tires are you running? I have done a search but am looking for pics as well.
I am having the Dobinson's kit and SPC UCA's installed at Main Line Overland next Thursday and was thinking about going up a size or two in tires. I currently have the stock rims which I will stick with for now and am running Cooper AT3 LT 265 65 18's. If you have gone up in size, could you also post some pics?
Believe it or not the wife is also pushing for the bigger tires!!!
Thanks in advance.
Old 07-17-20, 07:10 AM
  #1004
Deus
Deus's Avatar
Default Tire size
I have a 2011 GX460 that is stock. On stock suspension and 18" rims what size A/T tires can I put on without rubbing issues? What is the largest I can go? If anyone has pictures would love to see.
I am sure this has been addressed before just looking for updated opinions.
Thanks
JB
Old 07-17-20, 08:35 AM
  #1005
ASE
ASE's Avatar
Received 1,027 Likes on 685 Posts
265/65-18 ... same width, but 1-inch taller ... fills out the wheel well perfectly. Should have been the as-delivered size. Be aware that a taller tire may or may not fit in the spare tire location ... based on specific tire, and specific installed hitch.
The following 2 users liked this post by ASE:
MarkVII (07-17-20), ScaldedDog (11-28-22)
Quick Reply: Official GX Tire/Wheel Thread
