View Poll Results: Best 22 inch tire for 2014 plus GX460
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Official GX Tire/Wheel Thread
#1202
Not a very good pic as rims look bigger than this in person! No ride suffer and cheaper to replace the tires when worn down!
The following 2 users liked this post by 2LexusGX:
ebruce2 (05-20-22),
hilcountry (05-01-21)
#1203
SurfaceGuy,
Do your 275/55/20's rub at all? I am looking to get 18's or 20's. My worry with 20's is ride quality, but if 275/55/20's will fit without rubbing at all, then you really aren't compromising much sidewall to get better looking 20's. (159mm on 265/60/18's vs 151.25mm on 275/55/20's if I am doing my math right).
#1204
After spending hours on this thread I finally pulled the trigger on the wife's rig. Black Rhino Zion 6 20X9's wrapped in Goodyear Eagle II 285/50R20. Turned out really good and definitely doesn't look like a granny mobile anymore. Here's a little before and after action.
zippymbr (09-16-21)
#1205
I have been lurking here for quite a while and finally registered to say thank you for posting. I've been waiting for someone to post these exact 20x9 Fuel wheels on 285/50R20's.
JRT3 (04-29-21)
#1207
Will these fit my 2016?
Part Number: PTR2035110BK
Supersession(s): PTR20-35110-BK
- Off-road race-inspired 17-in. x 7-in. cast aluminum wheel with 6 lug nut pattern
- 11-mm. with 4-mm. wheel offset widens the overall vehicle track width by 0.9-in. (22 mm.) for more aggressive stance
#1208
Ahhh ... the beautiful but bulimic OEM Toyota Wheels ... why, but why, but why does Toyota put such narrow wheels (7-inches) on ANY of their truck based SUV's ?#? IMHO way too much sidewall bulge even when running 265 tires, so on-road handling is like riding on water balloons unless running E-rated tires with a stiffer sidewall. So unless you are a professional curb crasher or rock crawler, these wheels are way too narrow. Even the Lexus 7.5 inch wheels are borderline.
This is a good point. It’s a narrow rim. Can still take a wider tire. It also has a different offset than factory GX wheels so it sticks out a little more while being skinnier.
That being said I wanted skinny tires so I went with 255/17R17 tire. I love it.
Hehena (04-29-21)
#1212
All the 285/70R17's I looked at suggested a 7.5" wheel minimum and that is what I am running.
#1213
I agree. I was looking hard at the TRD wheels but did not like that they were 7". Depending on the width of tire you go with, the 7.5" wheels are a better option. They also don't have as much offset(+15mm) so should allow a little better tire clearance in the fenders. Oh, and you can get them for dirt cheap since every other person with a TRD OR 4Runner pulls them off the second they leave the dealer. I paid $400 for a set of 4.
I have some TRD wheels, in grey, coming and I too am concerned about the 7-inch width. I've seen guys put 275's and 285's on there but I think I'm going to stick with the stock equivalent for now (265/65R17). But even then, with 265/65R17, they vary on recommended wheel width with load rating / # of plys potentially being the determining factor.
Also, the set I ordered had a +4mm offset (PTR20-35110-GR). I guess there are multiple versions out there?
#1214
Nice rig.
The TRD OR wheels are +15.
