View Poll Results: Best 22 inch tire for 2014 plus GX460
285 40 22
50.00%
285 45 22
50.00%
265 40 22
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Official GX Tire/Wheel Thread
Old 10-17-21, 07:19 AM
  #1306
Seanzky
Seanzky's Avatar
If you wait long enough, someone here will change out their wheels and sell their stock grey ones to you. That, or check the BST (buy, sell, trade) forums in the meantime.
Old 10-17-21, 07:23 AM
  #1307
ukcats
ukcats's Avatar
I will have set of the grey painted ones with tires soon. Our 2022 is supposed to be here Wednesday, and will immediately order wheels and tires for it.
Old 10-17-21, 12:55 PM
  #1308
ukcats
ukcats's Avatar
Question. Planning on a 17” by 8.5” +1 offset wheel for he new GX. Any interference issues with the stock upper control with this size wheel?
Old 10-18-21, 07:48 AM
  #1309
ASE
ASE's Avatar
Received 1,027 Likes on 685 Posts
All Lexus GX460 wheels are a narrow 7.5" ... and when running the stock 265 tire, there is a significant amount of sidewall bulge that is not conducive to a sharp steering response ... and the stock wheel offset has the tires tucked WAY TOO inboard ... the very reason many upgrade the stock wheels to aftermarket wheels. So for the effort, do yourself a favor and purchase aftermarket wheels that are 8.0" wide assuming you are running the stock 265 tires ... in addition to having an offset that places the edge of the tire tread closer to being in vertical alignment with the edge of the fender flare. The stock Lexus wheels are WAY TOO inboard ... a "soccer mom" stance that makes the GX look like a Minivan.
If you do go aftermarket ... make sure the wheels have the stock 106.1 mm center bore diameter to avoid using centering rings to adapt a larger center bore diameter.
Slprciv (10-18-21)
Old 10-18-21, 08:45 AM
  #1310
Chasin
Chasin's Avatar
www.fnwheels.com Plenty of options out there.
httpOfficial GX Tire/Wheel Thread-in6sm5t.jpg
The following 3 users liked this post by Chasin:
ASE (10-18-21), Slprciv (10-18-21), ukcats (10-18-21)
Old 10-18-21, 01:46 PM
  #1311
ASE
ASE's Avatar
http
Nice Stance
Chasin (10-18-21)
Old 10-18-21, 01:52 PM
  #1312
Chasin
Chasin's Avatar
Originally Posted by ASE
Nice Stance
Thanks. its on factory suspension with factory size tires, except they are Toyo Open Country AT3s
Slprciv (10-18-21)
Old 10-18-21, 04:55 PM
  #1313
ASE
ASE's Avatar
Your rims are clearly wider than the stock 7.5" ... as is the offset. Please share ...
Old 10-18-21, 09:11 PM
  #1314
tonyrd1
tonyrd1's Avatar
Finally got the tires and wheels mounted 18x9 +0 Rays 57Trans-x with 265/70/18 Falken A/T3W
The following 4 users liked this post by tonyrd1:
eyi526 (02-01-22), m5rahul (10-19-21), Piney1 (10-19-21), Siblue (10-19-21)
Old 10-19-21, 12:17 AM
  #1315
ukcats
ukcats's Avatar
What are y’all’s thoughts about a SL vs XL tire for this vehicle?
Old 10-19-21, 08:59 AM
  #1316
Chasin
Chasin's Avatar
They are FNWheels BFDs: https://www.fnwheels.com/new-products/bfd/
18"x 9"
Bolt pattern (PCD): 6x139.7mm
Offset: 0mm
Backspacing: 5"
Centerbore: 110mm hub centric for Toyota applications
Old 10-19-21, 10:22 AM
  #1317
m5rahul
m5rahul's Avatar
That ^^ is bada$$ !!
Old 10-19-21, 11:14 AM
  #1318
tonyrd1
tonyrd1's Avatar
Thank you, definitely worth for 10 months for the wheels
Old 10-19-21, 02:13 PM
  #1319
Siblue
Siblue's Avatar
I just ordered 57DR-X yesterday
Hopefully doesn’t take that long.
Old 10-19-21, 02:48 PM
  #1320
Marcopo
Marcopo's Avatar
Default New 22 inch wheels installed
Thanks to everyone who has taken the time to post on this thread about the wheels and tires. After reading through it all, I decided on going with 22s. I went with Asanti ABL-28 Barons, 22x9.5 15mm offset. They are gloss black with gray tinted machined face. 22x275/45 tires.
Wheel shop said they wouldn't fit but thanks to all the feedback from this group i knew they would. They fill the wheel well perfectly. They are pushed out 15mm(10 vs OG offset and 5mm from wider tire) which leaves them still sitting just inside the top fender lip. From the three quarter and back view the stance is WAY better and the truck no longer looks top heavy.
I had the expected slight rub at full turn on that underskirt bolt in the front, which i switched out for a flat head. I went the extra mile and used a little length of wire to pull the lower rear underskirt back about a half inch, attaching it to the undercarriage just to be sure there would be no rubbing. Have put a couple thousand miles on it without issues so far.
Originally went with Nitto 420vs but they were un-balanceable due to hard spots. Shop switched them out for Hankook Ventus and the ride is now great. The ride with the 45 aspects has gone from spongy to sport, but still a nice luxury ride, not stiff as I feared.
Lexus GX460 with 22 inch Asanti ABL28 and 22x275/45
The following 3 users liked this post by Marcopo:
markdh (10-19-21), Piney1 (10-20-21), The Ikon (01-27-22)
Quick Reply: Official GX Tire/Wheel Thread
