View Poll Results: Best 22 inch tire for 2014 plus GX460
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Official GX Tire/Wheel Thread
#1366
Good to know about the other tool bowhun2r listed above. I use Techstream to swap my two sets.
Starting with 2020 you can self-register new TPMS sensors without TS or any 3rd party devices.
So if you do want to swap out winter/summer wheel sets leverage the info @Acrad posted and ensure your new wheel set leverages a compatible TPMS sensor for the truck.
mstrchief (01-09-22)
#1368
Hey yall, just picked up my wife's 2020 GX this past week. She really likes the look of the Black Rhino Morocco's, so I had a few questions I was hoping to get some confirmation on.
1. Looking at going 20x9 with +15mm offset, hoping to get flush to fender look, sound OK?
2. I've read a lot and seen a lot of 285/50/20 tires to go with the 20" wheels. So this is not even am inch overall diameter difference from stock 265/60/18, but obviously considerably wider. Do I need to stick with this max ratio, or can I go taller, like 285/55/20? That would give me 32.3" overall diameter, which is only 0.2" more than the 275/65/18 everyone seems to run without problem on stock setup. Or will the increase in width not allow be to go taller on the sidewall?
Thanks
Thanks
Can someone also confirm the +15 offset will sit nice and flush with the 20x9s.
Thanks
#1370
#1371
More like missing two.
aredub (01-17-22)
#1375
Yes they rubbed
Yes this combo rubbed. I removed the bolt, heated and pushed the plastic back and also cut part of the plastic off. Driver side rubbed more. Alignment tomorrow and will check again to see if more needs to be removed.
#1376
Hey all, one final question here (I hope). I know there has been some discussion on wheel spacers, and I understand the concerns. However, I'd like to hear from those that have used or have opinions on the ability to use very slim spacers without any issue with standard wheel studs.
Looking for possibility of adding 10mm spacers MAXIMUM without any conversion of OEM wheel studs. Is this possible? If not, is 5mm possible? Or are the standard wheel stud lengths that tight that absolutely zero spacers will be acceptable with stock wheel stud lengths?
Thanks
Thanks
#1377
Thanks
Thanks
Good luck!
#1378
I ran 3mm spacers on my ND using the factory studs to clear my calipers. For me and the folks I spoken with 5mm is the max with the factory studs. It's much preferable to get a wheel with the offset you want w/o using spacers. Of course that incurs a lot more cost... but there is something about doing it right and not having to worry about it. 10mm (at least for me) would be a no go.
Good luck!
Good luck!
#1379
Really apologize for all the questions. Just trying to avoid huge issues ordering wheels/tires that will show up and not fit.
Is there any reason the UCA or stock suspension setup up front would be different from a 2016 to 2018 to 2020? I've reviewed this thread multiple times and have seen numerous 22x9.5 with +25 offset (same as stock wheel), and one even with +30mm offset. Doesn't seen like there's been any issue other than liner rubbing, which I've already done the zip tie mod and front liner pull forward mod in preparation.
When doing these mods and just looking at the UCA, it seems so close like it's going to be a problem. But again, I can't imagine my 2020 is going to be different from the 2018 and 2016s I've seen here, at least hopefully not.
#1380
Saw this on the web at a the Lexus of Charleston sale lot. I’m not sure how the ride or why someone would spend the coin to put these on a sweet ride only to sell it but I like the look. Have to wonder how they are for smoothness - a 22 leaves no sidewall for absorbing the bumps. They are Black Rhino Spear rims.
Black Rhino Spear in 22
Not bad looking
Not bad looking
Piney1 (01-28-22)
