Vehicle Customizations / Lexus Personalized Settings (LPS)
Old 02-07-18, 05:09 PM
tecman
tecman's Avatar
Power windows and sunroof still work when you shut down the GX if you don't open the door.
The sunroof will open further if you press the button again.
https://www.clublexus.com/forums/gx-...g-sunroof.html
The following 2 users liked this post by tecman:
malmon (07-01-18), rocket930 (02-09-18)
Old 02-07-18, 05:13 PM
bbqsoup
bbqsoup's Avatar
If you have autolock turned on either with speed or when shifted into Drive, when you slam on the brakes hard and the car came to a stop, it will unlock all the doors by itself...good safety feature.
Just found this out this morning LOL.
The following 5 users liked this post by bbqsoup:
GB2011GX (02-08-18), malmon (07-01-18), php (07-02-18), Piney1 (11-28-21), tigmd99 (03-21-19)
Old 02-07-18, 06:55 PM
hzhao
hzhao's Avatar
Me too I was off the ramp didn't pay attention of my speed and had to stop at the traffic light at the end of ramp....... found that feature too.
Old 06-30-18, 08:36 AM
bbqsoup
bbqsoup's Avatar
Put the car in R to activate the rear camera, the touch Stop/Start to turn the engine off, you will have the camera on until you touch S/S again to turn off or turn on the car again. Good to when you want to monitor behind when stop in parking lot of waiting for someone
The following 8 users liked this post by bbqsoup:
303mtnGX (06-04-21), Acrad (06-30-18), DJJJ (11-02-19), HiloCruzer (08-20-19), malmon (07-01-18), mcomer (06-30-18), Otherone (07-02-18), tigmd99 (03-21-19) and 3 others liked this post. (Show less...)
Old 06-30-18, 12:59 PM
hzhao
hzhao's Avatar
Do you also get the constant beep buzz sound? On my 2014 GX, if push the S/S button when gear shift is in any position other than P or N, the buzz sound continues until you moved the shift to P or N
Old 07-01-18, 11:31 AM
bbqsoup
bbqsoup's Avatar
It only beeps if the power is ON, otherwise no beep.
What I did was, when engine is on, i shifted to R, press parking brakes, take foot off brakes then press on/off. Camera stays on and no beep. Even if I shift to P, the camera still stays on. I’m on the Acc power and not on ON
303mtnGX (06-04-21)
Old 07-01-18, 04:47 PM
2012GX460
2012GX460's Avatar
Couple of other customary Lexus parlor tricks...press and hold the fob "unlock" button and watch the windows
and sunroof open. Vents a hot car as you approach. Release earlier to stop part way down. Slip the mechanical
key out of the fob and insert in the driver's door key cylinder. Turn CCW and watch any open window/sunroof close!
No, you can not press the fob "lock" button to close because it overrides the Jamproof feature and you could catch
Fido's head the the closing window.
Tapping the steering wheel button "Mode" will take you from AM to FM to BT to....
Press and hold the "Mode" button to pause a CD or iTune track or to Mute a Radio station.
Touch the Start/Stop button once with your foot OFF the brake for Accessory
Touch the S/S button twice with your foot off for Power Windows/Sunroof without starting the motor.
Touch the S/S when you park but are still in gear...Accessory. Promise me you will remember to touch
the S/S one more time before exiting the car to really shut it down, I'm not coming to jump start you!
Which year/s are you referring to here?
I have the 2012 and holding the unlock on the FOB didn't do anything.......was it operator error?
Thanks
PhillipT (02-16-20)
Old 07-01-18, 05:34 PM
hzhao
hzhao's Avatar
Thanks
Key fob lock/unlock with close/open windows features can be set via Techstream. Default setting is OFF. However, if you are using those OBD-II mirror folding module, that feature is ON with the module. However, the "closing" function only operates on four windows, but not on Sunroof.
Old 07-03-18, 06:53 AM
Wadle5
Wadle5's Avatar
These are really cool things about the vehicle that have me more and more excited to drive one!
Old 08-24-18, 08:46 PM
2012GX460
2012GX460's Avatar
So, I'm not a computer programmer, but is there any way to incorporate any other changes yourself?
By that I mean, is there something that you can program yourself?
Are these options computer or engineering features?
Old 08-27-18, 03:11 PM
craigrpete
craigrpete's Avatar
Default Carista
I can’t keep straight what are dealer only vs settings you can change yourself but look at Carista. That app plus an OBD module lets you change all options yourself and I think the cost is really reasonable.
Old 08-27-18, 03:40 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,651 Likes on 2,390 Posts
Here is the settings customization sheet
10-13 without navigation
10-13 w/navigation
2019
2016
2019
2010-2013 without Nav
10-13 w/Navigation
The following 6 users liked this post by Acrad:
ltsr (03-19-19), mikedallas (05-30-23), nevetsvsx (09-04-21), paui4m (08-28-18), Philly01 (11-22-21), Richie7 (08-24-19) and 1 others liked this post. (Show less...)
Old 08-27-18, 04:17 PM
2012GX460
2012GX460's Avatar
Lots of cool features, thanks!
Old 08-29-18, 12:23 AM
erx808
erx808's Avatar
Default Hmm
Originally Posted by pikenp
may be this is not so much of a hidden trick, but i just learned today that my non-ml audio system can actually play dvds. Car needs to be in park, with emergency brake engaged.
maybe my dvd was a music dvd but what year is your gx , ill try again!
Old 08-29-18, 06:15 AM
User21c
User21c's Avatar
Press the phone ‘off hook’ button twice for auto-redial... handy!
Acrad (08-29-18)
Quick Reply: Vehicle Customizations / Lexus Personalized Settings (LPS)
