Vehicle Customizations / Lexus Personalized Settings (LPS)
#46
Just had a discussion with a member who had 2020, the auto flashing with tap is build in function now. However, for odd reason it was disabled. It can be enabled with either 3 or 5 flash via Techstream just as other Lexus models. Which make sense since 2020 GX share the instrument cluster Multi-information display now. In 2016 LX that I have, the flash relay is intergraded with cluster display and no longer a separate relay anymore. (BTW, the auto flashing function for 2020 GX is listed in Owner’s Manual).
#47
Super Moderator
If someone comes across the 2020 460 customization sheet for download or scan let me know.
Thanks!
Thanks!
#48
Eureka! Every day I learn something new! I was wondering how to remove that mirror and replace it with a sunglass holder. Gotta keep my Costas close at hand here in FL 😎
#49
Super Moderator
The 2019 version is the latest I see
https://www.lexus.com/documents/broc...MY19-GX460.pdf
#50
This overhead configuration is still the same on the 2020?
#51
Super Moderator
Diagnostics
Claimed '16+ but could include '14-'15 as well / Accessed through infotainment diagnostics
Voice call quality adjustments
O6uzj100 (11-24-21)
#52
learned this also later in ownership by using google after going to a drive-in at Laconia NH and desperately trying to keep the truck running(Ac on it was 90 degrees out)and kill the DLR’s.
#53
#54
What are you talking about? Auto flash what? High beams, turn signals, something else?
#56
#57
Super Moderator
10-13 with Mark Levinson
10-13 models with RSES (Rear Seat Entertainment System)
14+ models - ALL
#58
