GX460 UOA thread
Old 05-02-17, 04:16 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,638 Likes on 2,383 Posts
Here is a Blackstone report showing moly levels in the Mazda oil from my CX-5. 596 versus 178 average.
EDIT: Here is a report on another site of someone using Amsoil 0W-30 for moly comparison. I do have Amsoil 0W-20 for this next oil change. Never had a vehicle take so much oil before... although nothing in comparison to a big block diesel.
Old 06-12-17, 02:33 AM
danielTRLK
danielTRLK's Avatar
Your GX is diluting the oil with fuel, way too much, the fuel is washing up some of the piston alloy's and causing needless wear. Use a WIX XP oil filter and use either BioSyn PCMO or M1 EP and get your air filters changed every 10-15K. No way you should have that much insolubles for this engine.
The toyota oil basically can't handle the fuels aromatics. That's why you're having your wear issues.
Old 06-12-17, 09:22 PM
caesosa
caesosa's Avatar
Acrad,
let me know how it goes with this one. I'm not due an oil change for another 5000 but I would give that a shot if it makes a difference. My experience so far with a high compression engine is that it idles a lot smoother and runs cooler. Fuel efficiency...not really expecting more... but for the gx it would be nice. Currently with my wife doing all the driving during the week it is averaging a .... wait for it.... 15mpg. No highway at all Monday through Friday.
Originally Posted by Acrad35751
I'm gonna use Amsoil 0W-20 this first oil change but considering using the high moly 0W-20 Mazda oil I use in my CX-5 next time.
https://www.bobistheoilguy.com/moly.html
Old 06-13-17, 07:55 AM
danielTRLK
danielTRLK's Avatar
a high moly oil won't make a difference on that engine. Your engines are blowing fuel right past the rings. You need an oil that can address the fuels aromatics or close that ring seal. Otherwise you're GX's will continue to take poundings on the internals.
Old 06-13-17, 03:14 PM
Acrad
Super Moderator
Acrad's Avatar
Do you consider the oils you have listed above superior or equal to the Amsoil I currently have? I've had good luck with my Amsoil for the last 15-20 years.
https://www.amsoil.com/shop/by-produ...?code=asmqt-ea
The moly oil I reference I only use in another car because of the purported benefits and it is running in a stock motor at 13:1 compression.
Old 06-13-17, 04:22 PM
danielTRLK
danielTRLK's Avatar
Well that's a tough question. RLI's oil will smoke Amsoil, performance and cost wise is cheaper. M1EP is better suited in this engine that the Amsoil, although the SS is very good stuff to begin with.
If you're having issues with Amsoil SS, the only oil that will outperform it is RLI's BioSyn.
I'm going to be doing heavily discounted UOA soon, I will have a post out tonight.
Old 09-25-18, 05:46 PM
danielTRLK
danielTRLK's Avatar
Default GX460 Engine Oil
Here is a 10,000 mile oil sample with 115,000 on the odo. Could have gone much further, some poor lab work however caused me to prematurely dump the oil.
This is with Amsoil SS and a Purolator oil filter. I will have another sample shortly with their Boss version. Air filter is the Purolator, albeit may consider trying a cheaper filter from Amazon as I replace these every 10K. This was on mostly E50-60 fill ups. At the current moment, I can not justify the premium fuel cost to show some other things. In this period I also hauled a 6,000lb trailer for 2,500 miles or so.
I do have the E85 cleanse sample that shows how much crap was cleaned out of the engine if anyone is interested. Previous owner was a Nestle executive who only used premium grades.
I expect 20,000 mile intervals in the future.
10,000 mile sample.pdf
bbqsoup (09-26-18)
Old 09-26-18, 05:04 PM
Acrad
Super Moderator
Acrad's Avatar
Thanks! Does testing facility provide a chart for comparative normal ranges like the Blackstone reports display?
Old 01-28-20, 07:21 PM
LexusGXFan
LexusGXFan's Avatar
Default Used Oil Analysis
With the discussion going on with 10,000 miles oil changes and what weight of oil to use, do any members have a UOA (used oil analysis) for their GX with the oil flavor of their choosing ??
This is a very specialized group of owners on this forum and would be good to maybe start something.
I have a few but they are of some very low mileage runs and nothing for longer.
Old 01-28-20, 07:49 PM
nuclearn8
nuclearn8's Avatar
I'm gonna do Blackstone on the amsoil that's been in our GX since 22500 at 5k, 7.5k and 10k... will post results when we reach these mileage milestones
Old 01-29-20, 06:34 AM
Jacket
Jacket's Avatar
https://www.clublexus.com/forums/gx-...oa-thread.html
Old 01-29-20, 06:51 AM
LexusGXFan
LexusGXFan's Avatar
Thanks Jacket for the link.
Looks like I'm not the only one with fuel dilution issues on the 4.6L engine.
I use Oil Analyzers (Polaris) for my UOA and my fuel dilution numbers come back at 2%. Still in the green, but it is bringing the viscosity down a bit. Blackstone is good, but I don't like how don't have an accurate way to measure fuel dilution like Polaris does.
Thanks again for the link !
Old 03-26-20, 02:37 PM
nuclearn8
nuclearn8's Avatar
The first UOA for Lexi
Jacket (03-27-20)
Old 03-26-20, 06:00 PM
LexusGXFan
LexusGXFan's Avatar
Nice to see a fellow Amsoil user.
Great wear numbers.
I'm using a little different oil from Amsoil, but numbers are the same with the same miles between UOA. I've got 50k on the engine....
Old 03-26-20, 07:03 PM
nuclearn8
nuclearn8's Avatar
I'm gonna try Mobil1 EP cause it is more readily available at Walmart and $40 cheaper than Amsoil SS... I'm gonna let the UOA numbers bear out if it makes a difference.... unlikely since I'm planning 5,000 OCI.
Quick Reply: GX460 UOA thread
