OEM Fog Install in GX460 Base?
#61
Just wanted to post to confirm that my 16 is indeed pre wired for foglights.
MedinaJ78 (09-08-23)
#62
I recently installed some Hella Micro fog lights.
The following 4 users liked this post by Chasin:
#63
Since I tapped into the factory relay box, the fogs work like OEM factory fogs and are tied into the low beams. The foglight icon on the gauge cluster is also utilized and illuminates whenever the lights are on.
The following 5 users liked this post by Chasin:
#65
Super Moderator
Years ago on my old Nissan Maxima it did have factory fogs but when you replaced the broken fog lights they always included the replacement switch stalk that could be used in vehicles without option. Not sure if that is the case here
With Fog Lamps appears to be PN: 8414060301
https://parts.lexus.com/p/Lexus__GX-...414060301.html
Without Fog Lamp / PN: 8414060350
https://parts.lexus.com/p/Lexus__GX-...414060350.html
PN:8414060360
https://parts.lexus.com/p/Lexus__GX-...414060360.html
PN:8414060360
Creetopher (12-09-20)
#66
PN:8414060360
PN:8414060360
#67
If the fog harnesses are premiered as indicated here, I would assume the plug in on the switch stalk is highly possible. By looking as switch stalk, it is just a multi pins connector into steering wheel column, wondering the difference would be just missing few pins on the stalk without fog lights control.
#68
Well, as many of the GS owners will tell you, it's not always this easy. Many F-Sport owners wanted fog lights on their GS. There's a huge long thread in the 4GS forum about it. Getting the little indicator light on the dash always seemed to be the hardest part, not sure it was ever truly explained how some got it to work, and others couldn't. Also, the cleanest look is to get the stalk, but that requires so much extra work...removing the steering wheel.
It's nice to see that Lexus made it easy for the GX, if you wanted to add those lights.
#69
I ended up just purchasing ijdmtoy 2.25" projectors 9006 fitting, 9006 led bulbs, ijdmi 9006 wiring kit, and stock fit switch from amazon(i ordered blue, white would've been a better stock look). I did have prewired fog set up but decided i wanted the ability to turn the fog lights independantly from low beams. I bought some cheap bulbs at first, no good not bright at all. I did get some better 9006 led bulbs on sale. It makes a hug difference!
#72
Where u bought it from
I was cheap and didn't want to pay $1500 for just the fog lights.
I went ahead and did this mod last night ...using H3 projectors with HID conversion .. I will update with the write up instruction later when I get to the laptop.
... Posting by iPhone ...
http://
Will be using clear bulbs for the turn signal to get the clean look up front
http://
#75
I basically cut off the factory connectors and soldered my new wiring + connectors onto the factory wiring. I tapped into the factory relay box to control the foglights, and yes, I purchased a factory looking switch that fits into one of the empty slots on the left side of the dash. I highly considered purchasing a factory headlight stalk with foglight switch but I had already purchased the switch, so I decided to use it. I wonder if the factory headlight/signal stalk would make the installation plug-n-play.
