GX-460 Door Actuator Failure
#91
This was brilliant help!
Hello,
I recently had the rear door actuator fail. It started out slowly having issues, so I ordered the part. When I decided to install the part the door would no longer open so I thought I was screwed. Well, there is a way out.
See the attached PDF for instructions on how to replace the actuator IF you can open the door.
Now that I couldn't open the door this is what I did:
Open the rear hatch
Remove top panel
Remove all other panels (see PDF). I was not able to completely remove the bottom panel but I was able to see that there was a screw driver area at the actuator (RED)
Turn clockwise for a while, this will eventually unlock the door.
Inside the actuator you can see that the screw when turned moves a plate (red arrow), that hits a tab that will unlock the door (blue arrow)
With the door open you can replace the actuator normally.
Open the rear hatch
Remove top panel
The following 2 users liked this post by GXOffTheMap:
Bergy24 (08-07-24),
clearmysix (08-06-24)
BTXpress
GX - 2nd Gen (2010-2023)
97
06-26-24 08:21 AM
