Transmission fluid change
#376
This would be far more helpful if background music wasn't present. I think 1/2 quart could occur. I really don't know tolerance of the A760F as to what is too much or too little. IMO: If you work on your 460 you are going to want a working install of TS or something like OBD Fusion/Link anyway to read codes as general purpose OBD readers won't get you very far. These latter options will get you temps for carefree AT fluid change. Just my $0.02.
https://youtu.be/9NYYSvNVGT4
Acrad (09-17-20)
#377
I've had my fluid replaced by my the Lexus dealership in Plano, TX. They don't flush it completely, but the invoice states 7.7 quarts replaced. I did it once at 90K miles, and have continued to do it every 30K miles. I'm at 230K right now. The cost has been $140 every time. Cheap insurance IMO.
The following 4 users liked this post by TXGSF:
#378
Closing in on 100k miles and looking to see what others are doing. Trip to two Lexus dealers to inquire about a flush/filter service and both have adamantly stated to not flush at this high a mileage. One tech advisor went on to stay that in his thirteen years at the dealership, he has yet to see one fail.
I have had transmissions refurbished on other Toyota/Lexus products to be proactive, and because they were in extreme off-road competition scenarios in jungle conditions where they saw abusive use.
I'm personally not feeling that "gotta change the fluid just in case" sentiment. I believe the robustness of these vehicles, coupled with the light use they typically see, amount to many years/miles of rolling around the planet with legendary Toyota reliability. YMMV.
#379
Super Moderator
Unfortunately, without an external air AT cooler these transmissions run hot. I've yet to see anyone change fluid in their A760F that wasn't dark fluid even with 25k miles. I'm curious to see how much better my fluid condition is after installing the OEM external AT cooler. Mine was quite dark with 50-60k miles. They can fail.... extremely rare but nothing is completely bulletproof. I've probably heard a dozen stories among various forums or FB GXOR. Even the owner's manual states 60k miles if you tow or carry heavy loads. I did 4 drain and refills... it is pretty easy really if you use something to monitor temp and do some of your own maintenance. Just my $.02.
The following 2 users liked this post by Acrad:
JoshDrivin (09-18-20),
nuclearn8 (09-18-20)
#381
Super Moderator
I'm just running Toyota WS. I was a little hesitant to mix fluids but if you plan to essentially replace all the fluid you should be fine. Replacement fluids are always a hot topic for debate :-)
A few pics from here of pan, filter and valve body
#382
The following 2 users liked this post by Romanova:
Acrad (09-18-20),
#384
Alright, so this one has slipped through the cracks as the past few months have been crazy busy. I am nearing 140,000 miles (138ish atm) and I am planning on having the transmission drain and filled 3 times at duggy's garage this coming week. The fluid has never been changed so I am a little concerned about if it's a good idea to do it now but I have been going back and forth for a long time now and just getting it done for peace of mind seems like the right move. The only thing that concerns me is that they said they wouldn't change the filter. Is this a real issue? If I was just gonna use the GX for highway cruising like it has been for most of its life up to this point I would probably just leave it alone but I am planning on doing some light to medium difficulty off-roading in the future and I want to make sure the vehicle has the best chance of lasting under these harder conditions. Any responses are much appreciated!
#385
I did my first transmission fluid change at 135k miles. First, I drain and fill the pan. Then connected 10mm hose to return line and drain/fill 1.7L 3 times. Took the car for a drive and drain and fill the pan again. Then opened the overflow at 115F. The job took me 3 hours and 11.7 quarts of Toyota WS fluid. The car shifts smoother. The fluid that came out was black.
#386
#387
I think someoneon this forum already discussed the 'filter', which is not a real filter but a strainer, so not really a point of changing it. I have done the tranny fluid drain and refill three times at 95k and did not venture into filter changing. I did always filter change on my BMWs, but it comes with the new plastic (!!!!) tranny pan, so no additional effort, you just throw away the old pan and install the new one.
#388
. but the color of the fluid was burnt, and i never ever towed anything.
The Gx has the tendency to 'jump' from a stop when the accelerator is pressed and I hate that 'feature'.
WRD4chano (11-21-20)
#389
The Genuine Toyota WS fluid is NOT a full synthetic fluid.
As Acrad stated above, these transmissions do run on the warmer side and some ATF fluid cannot deal with the higher temps.
I'm not a dealer for Amsoil, but if you really want the best ATF, use the Signature Series Blue or Red cap fluid. Toyota WS is a fluid to get the car to the end of the warranty.
LeX2K (11-22-20)
#390
