#Transmission fluid change
#586
If you are doing it via drain/fill it will take about 15 liters to replace almost all the fluid. A more sensible method I like to use is initially do 3 drain/fills then after that 1 every oil change until I'm satisfied.
#587
https://www.homedepot.com/p/HDX-5-qt...5024/300225941
#588
You will need five quarts. I used a home depot five quart pail to measure what was drained and it was a bit over four quarts.
#589
Agree per the description. Each drain is limited to the fluid volume in the transmission pan ... about 3-odd quarts ... much stays in the torque converter and transmission valve passages ... hence the need for multiple drain(s) ... so with repeat transmission pan drains, the new fluid is mixed with the old ... until the mixed fluid is mostly refreshed if one is so motivated. Many just do 2-3 drain and refills on a regular basis. The 15-quart reference is if one wants to get close to a complete new fluid refresh in one session ... but again, this requires repeat 3-odd quart transmission pan drains and refills to accomplish ... obviously mixing the fluid between drains.
#591
Transmission Fluid Drain & Fill Done Correctly?
Was doing some routine maintenance (prefer to than bringing for service) on my ‘23 (I drive a lot) and decided to check the fluid in the pan. was surprised to see that under 50k miles the fluid was starting to brown, barely any red, so I drained it. I left the fluid in a pan over night to cool off, came back the next day and measured a little over 2.5 quarts. Used a hand pump to transfer that exact amount(Toyota AWS) back into the fill plug.
Started the engine, let it warm up, shifted into all the drive modes & gears multiple times.
Now this could be all in my head, but a couple days later I think I’m noticing my upshifts to be a little more noticeable than they were, which is making me feel like I should add maybe a half a quart more or something? Anyone have experience or advice on this? Might be worth nothing, I also switched my engine oil to Amsoil Sig 0-W20, and my air filter to a K&N during the service. Throttle seems peppier after this.
Thanks a bunch.
Thanks a bunch.
#592
2.5 quarts sounds low, IIRC the capacity is closer to 4 quarts. Also there is a dedicated procedure to correctly fill the so-called sealed transmission. Many videos are our there, here is one.
Personally, I would stick with the OEM air filter, but that debate is never ending
#593
#594
Yes ... the truck needs to be level for maximum drainage ... and to ultimately (more importantly) use the transmission pan overflow drain to finalize the fluid level. I drive the front-end up on ramps ... then use a floor jack under the rear differential to lift to level, and place jack-stands under the rear frame or axle tubes.
#595
#596
#597
Also question, can driving on these trannys .5 to 1 quart under or over for a couple days cause anything significant?
#598
Don't need a Scan Tool ... use an infrared temperature gun on the transmission pan ... close enough.
#599
I did one better; ordered an OBDLink MX+ to arrive overnight. Always needed a solid scanner regardless, esp for my 01 Tundra. Plan on doing in the morning. Last question; what is the socket/key needed for the overflow check plug?
#600
Alright so just want to add for anyone who has, or will experience this. So after my first drain & fill a week or so ago, I noticed shifts were a little more noticeable and not as seamless as I’m accustomed to. So today I put the truck back on the ramps, waited for temps to hit 115-126 range, and opened the check valve and drained out about 1/3 of a quart more. Got her back on the road, and happy to say MUCH smoother.
I’m guessing my overcautious self wanted a little extra as opposed to the contrary, and all it did was raise my anxiety for a week lol. A word of advice; you’ll hear the “trickle” word as the point of capping the check valve up, which is correct, but take it literally to the point of where the fluid stream goes from barely flowing, to actually beginning to turn into drops.
Cheers.
Cheers.
