Transmission fluid change
#631
Toyota dealer quote for drain and fill or flush
Stopped by a local Toyota dealer (not the one I normally go to) and inquired about AT service. They can do either a:
drain and refill of 3 qts @ $480.00 for this service; or
a full 12 qt flush for the bargain price of over $600 (assuming I bring in my 3 qts of WS).
The pricing is simply absurd. Sorry, Ill do my own drain and fills with my 6 qts (@$12.50 per qt approx from a different Toyota dealer).
Just an fyi for those interested. Seems like others had dealers do a d&f for under $180. Ymmv.
I also was surprised at approx $400 quote for coolant d&f radiator only, not including block drains. I already did my radiator with 1 gallon sllc pink for $21 plus the lisle spill free coolant funnel kit.
jphowey (09-06-24)
#633
The pricing is simply absurd. Sorry, Ill do my own drain and fills with my 6 qts.
I do the ATF "flush" by disconnecting return line at (pinned) thermostat on transmission, and briefly run engine 30-60 seconds to pump out old fluid out and fill as I'm going. I'm debating installing an in-line Magnefine filter in same location. I've done it on 2 old (cheap...) Volvos I have as test run, and it works like a charm
And I also love that Lisle spill free funnel with assorted adaptors for various radiator caps (Well....Amazon knock-off. I'm cheap). I can't believe I struggled for years doing coolant with soda bottles cut in half, duct tape, etc. Thanks ClubLexus!
JeffS520 (09-06-24)
#634
Did my first drain and fill with the Toyota ATF WS this morning at about 57,500 miles. Just returned from road trip to Colorado. Put gx on rhino ramps in front. Removed fill, then drain and overflow plugs.
First drain was 3 quarts from drain plug even on ramps. Nothing from overflow plug. Refilled with 3 qts then cycled gears. Drove for 20 miles. Felt fine. Will do 2 more and the last one Ill add a bit more (1/2 qt). Then do temp check with obd fusion and open overflow plug.
Only difficulty was getting the fill plug off. Might need to use a smaller ratchet next time. Just awkward position and needed better lighting. Used a small flashlight b/c couldn’t find my larger light.
All the info on this thread was helpful. 2 more d&f to go. The factory fill was brown and I saved some to send off to lab for UOA. (Along with diffs, tx case and oil).
Thanks for all the advice and procedures here!
Adding photos of used atf-ws from first and second d&f. May wait a month for the 3rd d&f. 6 quarts total replaced so far.
The following 3 users liked this post by Gxme99:
#635
Keep us posted on the UOA? I have not seen any analysis posted for transmission servicing so I am very curious about their feedback and report!
Gxme99 (09-29-24)
#636
tntcandy (10-04-24)
#639
I pinned the thermostat open and fluid came out of both the thermostat side and cooler return line side. Still flushed through new fluid though.
#640
Just rolled 200k miles on my 2010. Had the shop change out the filter and fluid....they had to do several flushes cause of how black the original fluid was. Definitely should have done it sooner, but good luck to those that plan on never changing their transmission fluid
#641
