GX460 Remote Engine Start (RES & RES+)
Old 12-30-19, 01:35 PM
  #196
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
That hood latch sensor plugs into A24. Might want to see if connector is taped up in harness somewhere.
Old 12-30-19, 03:40 PM
  #197
ObsidianBl
ObsidianBl's Avatar
This might not be too much help, but if the OEM RES doesn’t work out, would the one @tecman linked to work? It’s from 12vSolutions
https://www.12volt.solutions/product...-1-smart-key-1
A GXOR member recently installed it on a 2016
Old 12-30-19, 03:51 PM
  #198
Acrad
Super Moderator
Acrad's Avatar
I saw that one on GXOR but am concerned it uses a OBD2 splitter. I wonder if this simply shuts off after the startup process? This can cause issues according to IIRC....Carista developer in thread here at CL.... and others as well I have seen online.... if you are running other devices at the same time on OBD2 bus.
Old 12-31-19, 11:40 AM
  #199
cancruiser
cancruiser's Avatar
Originally Posted by Acrad
cancruiser: Have you confirmed/tested your vehicle alarm to see if it goes off by opening the door inside while armed or if nothing happens with hood open as well?
O.K.. confirmed today.
While the alarm is armed, opening the hood doesn't activate it. Opening any of the doors does.
So, confirmed there is no hood switch
Old 12-31-19, 11:44 AM
  #200
Acrad
Super Moderator
Acrad's Avatar
Any bulges in the wiring harness that makes you think sensor connector might be taped up here?
Old 12-31-19, 11:48 AM
  #201
Acrad
Super Moderator
Acrad's Avatar
EDIT: I also checked 2010 and 2019 owner's manuals for US models and they state hood should set alarm off.
In my 2012 owner's manual it shows hood as being part of theft deterrent. Notice it includes the hood. Does your paper manual state hood should activate alarm?
https://lexusgxor.com/_media/general...ers_manual.pdf
Old 12-31-19, 12:11 PM
  #202
cancruiser
cancruiser's Avatar
Yes, it does state in the manual that the hood should set off the alarm, but it doesn't!
I'll check the presence of the connector on the harness and report back..
See correction below
Acrad (12-31-19)
Old 12-31-19, 01:17 PM
  #203
cancruiser
cancruiser's Avatar
CORRECTION:
I decided to repeat the test again. Opening the hood DOES set off the alarm but in my case, I have to raise the hood enough to unlock the safety latch. Simply lifting it up a couple of inches does nothing. My apologies for the hurried test and results from last post
This still leaves me with the RES install issue. But glad to find the hood switch works (although I am unable to actually see the switch!)
Old 01-06-20, 08:58 AM
  #204
cancruiser
cancruiser's Avatar
In my efforts to get the RES working, one thing that I was advised to do, and already did a couple of times, was to completely reset the ECU by disconnecting the battery for approx 30 mins. I did this in two separate occasions each was approx 4 hours, not only 30 mins. I assume this should reset the ECU, however, I did notice that my seat settings and radio stations were still present after I disconnected the battery back on. Makes me wonder if this was a true reset of the ECU or are these functions served by another computer?
Old 01-06-20, 01:22 PM
  #205
downshift1
downshift1's Avatar
I believe some of them are saved on the hard drive?
Old 01-06-20, 01:53 PM
  #206
Acrad
Super Moderator
Acrad's Avatar
Yeah like downshift1 said....I believe I have read 10-13 save those settings to hard drive as well. I assume '14+ either saves them to internal memory or map SD card. Any '14+ owners with battery swap scenarios?
Old 01-07-20, 05:45 AM
  #207
Jaerok
Jaerok's Avatar
I bought a plug and play system from https://accessorides.com/ Which i think does not use the OBD II port but uses the ECU connector (if theres a difference?) Just search for GX remote start
Gives you options for OEM keyfob, 1-way (with OEM), and 2-way remotes (with OEM).
Used code TRDJON for $15 off.
Going to install this week.
Use the 12volt solutions install video on how to get to the connectors. Programming is similar but different.
Old 05-09-20, 05:58 PM
  #208
ninja250
ninja250's Avatar
Default Back to the original topic - remote start question
I am planning to get and install the remote start kit PT398-60112, are there any complications with the installation ? Missing wiring in some models, etc.
Old 05-09-20, 06:00 PM
  #209
Acrad
Super Moderator
Acrad's Avatar
Other than 10-15 only ...it would appear Canadian vehicles are not compatible.
Old 05-09-20, 08:17 PM
  #210
ninja250
ninja250's Avatar
Perfect, thanks for the info, mine is 2015, us. Unfortunately it is not compatible with the subscription system, I have tried but its 2016 and younger vehicles.
Quick Reply: GX460 Remote Engine Start (RES & RES+)
