GX460 Remote Engine Start (RES & RES+)
Old 11-28-20, 08:14 PM
  #241
markdh
markdh's Avatar
Just wanted to throw out another option for anyone looking for a remote start.... I purchased a system from crutchfield. What I really liked about the system was optional the two way remote!
iDatastart CMHCXA0 Digital remote start system — uses a vehicle-specific T-harness (sold separately) at Crutchfield
t-harness
iDatastart ADS-THR-TL7 Remote start T-harness for select 2010-up Toyota and Lexus vehicles at Crutchfield
2 way remote
iDatastart RF2312A RF Kit Two 1-button 2-way remote controls for an iDatastart remote start system — 3,000-foot range at Crutchfield
mudmoose (04-01-21)
Old 11-29-20, 05:02 PM
  #242
Heaveyfoot
Heaveyfoot's Avatar
Originally Posted by markdh
Does this option let you lock the doors while the car is running so you can run into the store without having to shut the car off?
Old 11-30-20, 02:55 PM
  #243
markdh
markdh's Avatar
I have never tried, but if the car is running in remote start mode it will shut off when you open the door.
Old 12-07-20, 07:08 PM
  #244
Victorgrau
Victorgrau's Avatar
Question Need some HELP Remote START GX460
Hello I need some HELP by instruction on this forum installed remote start OEM system after make everything by instruction all worked, I was able to activate module and my hazard light blink once like it should be, but my car don't start re try to activate module couple times and all work ok but car don't start from FOB
my care is Lexus GX460 2014 try true two different computers (PC TEchstream) (Autel MAxidasElite) true both activation show ok and no codes stored in modules but car don start only when I check remote start log(live data) it shows me like something is not ready
picture attaced
please help to figure out
Noticed when hood is open getting code (Factory trouble code 07)
what is code (Factory trouble code 01) value 80 ?????????????????
Thank you !!
Old 12-08-20, 03:07 PM
  #245
Acrad
Super Moderator
Acrad's Avatar
Received 3,652 Likes on 2,391 Posts
Unfortunately, I don't have documents that state what codes are in that system as it was apparently not available worldwide. One would probably have to look in TIS
https://techinfo.toyota.com/
I see you mentioned the one blink
https://www.clublexus.com/forums/att...s-ac6a39f2.pdf
Did you see the double flash on page 19?
Old 12-08-20, 03:19 PM
  #246
Acrad
Super Moderator
Acrad's Avatar
Old 01-23-21, 10:38 PM
  #247
LaneW
LaneW's Avatar
Default Remote start option for 2014 GX 460
New owner of a 2014 GX 460 Luxury. Learning. My wife wants remote start. I see info about startin g with the fob with a sequence of buttons, but apparently mine does not have that option. I also see that maybe Enform can be used and have the app, but no start option. I would rather not have to use a second fob for an aftermarket remote start..... what are my options?
Thanks
Tiger12 (01-24-21)
Old 01-24-21, 11:59 AM
  #248
Tiger12
Tiger12's Avatar
Thanks
Welcome to the club! Recently purchased a 2015 GX 460 Premium and I was told by Lexus that 2015 and lower you can have the enform app for safety connect but not remote start. Unfortunately you will most likely have to go aftermarket or find a way around this. Looking at a Viper System as the time to open the app and start the car is a lot more responsive then the Lexus app I have heard.
Old 01-24-21, 12:20 PM
  #249
Acrad
Super Moderator
Acrad's Avatar
You can either install RES (10-15 models except from Canada)
https://www.clublexus.com/forums/gx-...l#post10165854
or 12V.solution
https://www.clublexus.com/forums/gx-...l#post10692345
https://www.12volt.solutions/product...8d8c1894&_ss=r
Piney1 (01-25-21)
Old 01-24-21, 10:39 PM
  #250
LaneW
LaneW's Avatar
Thanks. I am fairly handy, but this may be over my head. Which approach is the easiest to install myself?
Old 01-26-21, 01:34 AM
  #251
Acrad
Super Moderator
Acrad's Avatar
I’ve installed OEM but the 12V Solution looks easier and doesn’t require Techstream. It still uses factory FOB as well.
There are other distant (cell) starter options as well but I believe most of those are installed by shops.
Old 01-26-21, 08:06 AM
  #252
LaneW
LaneW's Avatar
Thank you. I will look into the 12 V Solutions
Old 01-26-21, 09:27 AM
  #253
mcomer
mcomer's Avatar
Understand the desire to have only the single Lexus fob for this but be aware that the
factory fob is the weakest link in this chain. The published range is '80 but your mileage
may vary! The aftermarket systems have more useful range and may (higher priced
versions) be "2-way" which transmits back to the fob that the vehicle successfully started.
IanB2 (01-26-21)
Old 03-28-21, 09:17 PM
  #254
jwilste
jwilste's Avatar
I have a 2012 GX460. I just bought the PT398-0T090 in hopes I could piece together the RS system. Does anyone know the part number of the v4 harness? I have not been able to find it anywhere. Thank you.
Old 03-29-21, 07:00 AM
  #255
Acrad
Super Moderator
Acrad's Avatar
Unfortunately, I don't remember seeing a PN for this harness.
Here is what I would try:
Check out the national auto wrecking yards searching out 2010-2015 460s and run the VINs at Lexus site checking the build data. If it was dealer installed then won't likely show up but if factory/port might be a way to obtain a used harness.
https://drivers.lexus.com/lexusdrive.../vehicle-specs
One caveat I can think to this is I have seen the full harnesses pulled out for sale and they may consider this part of the full vehicle wiring harness and not being willing to separate it.
jwilste (03-29-21)
Quick Reply: GX460 Remote Engine Start (RES & RES+)
