GX460 Remote Engine Start (RES & RES+)
#271
Super Moderator
#272
#273
Super Moderator
If Lexus doesn't end up giving free short range remote start on '16+ then I would say yes...
https://www.12volt.solutions/collect...-1-smart-key-1
#274
Also, the 12volt solutions is preferred over stuff like this because of the harness vs splicing, right? https://shop.mypushcart.com/oem-acti...push-to-start/
#275
Super Moderator
I don't recall that other unit but have heard of many successful installations of the 12Volt Solutions option
#276
Your engine shuts off because your RES disarm input wire was not connected. All quality RES have a disarm input as well as an output wire in order to disarm your vehicle while the engine is running. The Lexus factory disarm wire is typically a light green wire located at the BECU in a white 30 pin plug, pin #24. The BECU is located to the right side of the underdash fusebox. This same light green wire will unlock your driver's door with 2 pulses. But if you are buying those "plug and play" type of RES, then you might be lacking those options.
#277
I bought a 2014 GX Premium earlier this month. The original window sticker was in the glove box, and it lists remote start in the Premium options. The remote has 4 buttons, lock/unlock/rear window open/panic. What am I missing, does it not have remote start or is there some secret sequence on the remote to start the vehicle? Owners manual is no help on this. Thank you.
#278
Statman (04-24-23)
#279
FYI, press lock twice within 2 seconds or it may not register.
#280
Wonder if all Premiums have Remote Start functionality built-in, or was/is it an option ?
#281
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/img_0079_9ee11d9e0cf32da1a21c044c7d1eb2f7b5b2ad76.jpeg)
Acrad (04-25-23)
#282
Super Moderator
RES and RES+ were options for 2010-2015. I installed RES in my ‘12 years back… there was also a sticker that went under the hood with the kit.
#284
#285
Super Moderator
@jakemccurd
Jake posted a video over on IH8mud that his RES still keeps running when back door is opened.
I personally haven’t test mine. I don’t recall ever trying or this being expected behavior.
Does it work just like other doors on everyone else’s and kills the motor on open?
