GX460 Remote Engine Start (RES & RES+)
Old 04-08-18, 02:49 PM
  #61
hzhao
hzhao's Avatar
It's basically the remote lock/unlock distance. That's the major difference with Enform option which you don't have the physical distance limitation of the key fob operation range as long as the vehicle under cellular signal coverage. I never used remote start in real life as I don't have too many situation the car was outdoor for long time.
bbqsoup (04-08-18)
Old 04-08-18, 02:54 PM
  #62
Acrad
Super Moderator
Acrad's Avatar
Received 3,616 Likes on 2,367 Posts
15-20 feet though should be fine for my use. Vehicle is usually that close to cabin. I'd love to have the Enform option but OEM non-starter with my model year. Probably some 3rd party options though.
Old 04-08-18, 03:03 PM
  #63
hzhao
hzhao's Avatar
I think Lexus only made Enform remote start option available to GX after 2015 model year (if I am correct).
Old 04-08-18, 03:18 PM
  #64
Acrad
Super Moderator
Acrad's Avatar
tecman: Thanks! Far more distance than I would normally need.
Old 04-12-18, 08:02 AM
  #65
Gxxr
Gxxr's Avatar
Aside from climbing under my dash to look for this module, is there an easier way to see/discover if our 2012 GX460 already has the remote start module on board?
Old 04-12-18, 08:34 AM
  #66
pinoyesv6
pinoyesv6's Avatar
just try to start the car remotely. press the lock button two times and then press it a third time and hold it down for 3 seconds. the lights should flash each time you press it but then will blink and start the car after the 3rd time.
Old 04-12-18, 12:35 PM
  #67
Gxxr
Gxxr's Avatar
well...... no luck. Looks like I don’t have remote start. I tried the procedure three times and nothing happened.
Thanks for the directions!
Old 04-12-18, 12:47 PM
  #68
bbqsoup
bbqsoup's Avatar
That is FAR! I wish I have that range LOL.
Old 04-12-18, 12:48 PM
  #69
hzhao
hzhao's Avatar
If I am not mistaken, starting 2015 (or 2016) model year, Lexus has changed GX remote start as Enform subscription based instead of hardware module based as before.
Old 04-12-18, 12:49 PM
  #70
bbqsoup
bbqsoup's Avatar
If you're registered on the Lexus owner website, you can email them with your VIN and ask for a build sheet of your GX. It will list all the options that came with the truck new. It's nice to have.
Old 04-12-18, 01:40 PM
  #71
Gxxr
Gxxr's Avatar
nice, I will do this!
Old 04-12-18, 01:58 PM
  #72
tecman
tecman's Avatar
I have a sticker under the hood.
Old 04-12-18, 02:21 PM
  #73
hzhao
hzhao's Avatar
Other than on the hold, I also have two window sticker on both sides of front windows:
Old 04-13-18, 12:50 PM
  #74
Black16
Black16's Avatar
If you dont have enform and want to use the remote start via an app/phone you can use the "RES+" module. The install is a bit more difficult and i think requires a minimal yearly subscription but its much better than the cost of enform and completely eliminates the FOB distance factor.
Unfortunately i dont think anyone has found a way to bypass the shutoff besides going aftermarket. The factory remote start is heavily integrated into the vehicles ECM so its probably not going to be as easy as cutting a wire or removing a fuse.
Old 04-13-18, 01:43 PM
  #75
Acrad
Super Moderator
Acrad's Avatar
Factory unit almost looks trivially easy to install. Just the harness into ECU and then another into main BUS connection and then another connector that is only used during installation and then disconnected.
I probably won't get to this install until early May though. If I do find distance limiting I might play with ways to make it greater.
Quick Reply: GX460 Remote Engine Start (RES & RES+)
