GX460 Remote Engine Start (RES & RES+)
Old 01-23-19, 06:13 PM
  #91
Stacey2447
Stacey2447's Avatar
Default Remote start
Is there any way for car to stay on with remote start once you touch door handle.
Old 01-23-19, 06:36 PM
  #92
mgs1995
mgs1995's Avatar
This has been discussed before. It is a bit annoying but it is considered a "safety feature". I'm not sure what the thinking was. I don't think anybody has found a work-around.
Old 01-23-19, 06:54 PM
  #93
Stacey2447
Stacey2447's Avatar
Ok thank u anyway! It’s very annoying. 🙄
Old 01-23-19, 07:26 PM
  #94
JonGX
JonGX's Avatar
Agree that it's annoying but definitely a safety feature. I have small children and use the remote start every morning to warm up the car before taking them to school. They often walk out the door right before me and I wouldn't want them to be able to get into a running car without someone in the driver seat.
Oddly though, I was traveling for work earlier this week and had a Ford Fusion Hybrid as a rental car. I was able to open the doors and get into the car while the car was running, but as soon as I put my foot on the brake, the engine shut off. Seems different manufacturers have different ideas of how to implement these systems.
Old 01-24-19, 08:29 AM
  #95
mgs1995
mgs1995's Avatar
But the doors are locked when you remote start, right? You can’t get in without the fob.
Old 01-24-19, 06:18 PM
  #96
John00
John00's Avatar
many vehicles will stay on, and shut off when the brake is pressed. the idea is that you cant move the vehicle without pressing the brake and shifting into gear. definitely can be worked around but no one who can do it wants to, or has, or has shared what they did.
Old 01-25-19, 01:18 PM
  #97
mattwymore
mattwymore's Avatar
Default please help
Originally Posted by Black16
It took me about 2 hours to install the module using the provided instructions. Getting techstream to work....about 6 hours
i cant get my hazards to blink even once
Old 01-25-19, 01:33 PM
  #98
Acrad
Super Moderator
Acrad's Avatar
Received 3,637 Likes on 2,383 Posts
A lot of timed specific steps that have to happen in short order. What page of steps is it failing at? I haven't looked at that document in quite some time now.
Old 01-25-19, 01:48 PM
  #99
mattwymore
mattwymore's Avatar
so instructions say to cycle acc to on 5 times after you plug in the res 1 plug connection and shut the doors.. afterwards i should get the hazards to blink in recognition...i do the cycle but no hazzard blink.
Old 01-25-19, 01:53 PM
  #100
Acrad
Super Moderator
Acrad's Avatar
• Short pin already installed in the fuse block? Page 14
• Leaving hood open?
• 14 hits of the start button starting from OFF and ending at ON?
OFF →Accessory →ON
This is all before the TS instructions.
If you are confident wiring is all good you might have a bad remote starter module.
Do you know if Techstream sees the module? Now in the page 17 area. Not sure if it will show up or wizard will even launch if module wasn't connected to vehicle.
Old 01-25-19, 08:33 PM
  #101
mattwymore
mattwymore's Avatar
Default please help
anyone know how to actually sinc it to my car? the sequence doesnr seem to do anything. not even the flashing hazards if it fails...
Old 01-29-19, 02:43 PM
  #102
mike2937
9th Gear
mike2937's Avatar
Default Vin decoder says I have remote start
Hi folks!
2010 GX460, the VIN decoder read it has remote start, but no fob, as I bought used.
Any ideas how to go about getting this to work?
Old 01-29-19, 02:44 PM
  #103
Acrad
Super Moderator
Acrad's Avatar
https://www.clublexus.com/forums/gx-...ine-start.html
Old 01-29-19, 03:16 PM
  #104
cancruiser
cancruiser's Avatar
If it is factory OEM starter, check for the presence of stickers on the windshield and under the hood (driver side)
Old 01-30-19, 06:05 AM
  #105
mike2937
9th Gear
mike2937's Avatar
I works , thank you!
bbqsoup (01-30-19)
Quick Reply: GX460 Remote Engine Start (RES & RES+)
