Cost for Hub and Wheel bearing replacement?
10th Gear
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
I live in Dallas and the Lexus dealership here(Park Lexus) want $1,100 to replace the hub and wheel bearing for the front driver side on a GX460. Is this a fair price?
Seems a little high. The part itself should cost around $300-350 and the labor should be around $400-500. I'd say $750-850ish would be fair for the hub/bearing assembly. Not sure how you feel about an independent shop doing it, but it should be substantially less. Good luck!
That's expensive for such a simple job. I replaced the wheel hub assembly of my LS430 myself for half an hour with a $75 non Toyota parts. After 40000 miles, it's still OK. I say definitely shopping around independent shops. It's simple job and simple parts.
Other than the free services for the 5k and 10k on all my other Lexus vehicles I rely on a local shop to do the job. Tons cheaper and no problems. Toyota (or non-Toyota) parts are cheap and labor will be a lot less as well. I don't need the free latte or massage chair.
Cheap: DURAGO 29596012 @ rockauto etc, $67
Premium: http://bluepitbearings.com/2010-2014...el-Bearing.php $279.
How to:
No air/electric impact wrench? Use 3/4" drive breaker bar with 36mm socket (look on amazon.com or harborfreight.com etc)
Job's done
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Call and price Toyota dealers, or local shops. Toyota dealer here was about $800. I did both on my 4Runner. You will need a BFH and chisel to get it off. I bought the loaded hubs from the seller in the above video on eBay. Don't buy the cheapest stuff you can find.
For reference an indy lexus shop (Clear Choice of Houston) quoted me $660 for one side but I ended up doing it myself. That does not seem bad after the feedback above.
A few additional pointers if you want to do it yourself following the video above:
Job it totally doable.
So far i have successfully done the following myself on this car:
Replaced air springs in the back
Replaced all 4 shocks from adjustable to non-adjustable
Replaced 8 spark plugs (this is a PITA!)
Serpentine belt replacement (this is a PITA!)
Front driver bearing hub replacement
I'd be happy to share details
- Always buy from reputable sources. Ebay is "tricky" (unless you know ur sellers) - amazon is more reliable. Of course other trusted sites are also good. I bought the bearing/hub assy for $150
- I first tried to buy the bearing and the hub separately and have somebody press them in for me... Not worth it! Buy the pre-assemble bearing and hub with the o-rings and seals.
- Get yourself a good chisel. You'll need it. Make sure it widens to at least 5/8". This was the most time consuming part as I didnt have a decent chisel
- When removing the dust cap, i messed mine up (perforated the thin wall). I didnt have the proper tool. After that I ended up sacrificing an old flat screwdriver and grinding the tip as a mini chisel to initially separate the cap from the hub driving it between the cap and the hub. Once you get it 1/16" separated it's a piece of cake.
The following 2 users liked this post by Eliris:
Acrad (11-25-19),
GoldenGoon (02-25-22)
Once I had the parts and the tools (Oreillys Auto Parts loans tools with deposit) I was able to do this job in 2 hours in my garage. Make sure to use penetrating oil on all the bolts and then walk away for a while, also don't get it on the brake pads.
Super Moderator
I would love to hear a detailed writeup. I haven't had to deal with this kind of repair since I had an old '87 Nissan Maxima back in the early 90s.
Well technically there isn't much more to it than what you see in the video, and my comments above... I didnt use the penetrating liquid, so that would've probably helped my rudimentary chisel to get the assy out.
but if youhave any specific questions lemme know.
Acrad (11-28-19)
Just swapped the wife's tires thinking it was making tire noise. A grand later we have Michelin defenders and the same noise. Guess it's time to check wheel bearings. What brands would you guys suggest? I see they make a "module" or a complete hub assembly. Anyone have any helpful hints or past experience?
For the fronts go with NSK which are $61 each from Amazon and should just bolt in IIRC. NSK are made in Japan and are going to be better than Dorman, Beck/Arnley, etc. You can also try Timken which may just be a reboxed NSK. Make sure you do some more checking before you fire the parts cannon at the car...
If it's the rear, I would go OEM or Centric. Check Rock Auto for prices.
Chaos236 (02-29-20)
Get the wheels off the ground so you can try and shake the tire at top and bottom and side to side. Then spin the wheel slowly and see if you hear any noises, grinding, etc.
What year is the GX and how many miles? If it is the bearings, you shouldn't be having a failure until at least 150k. Of course, driving conditions, climate, etc will work to shorten or lengthen the life span...
