Interior and Running Board LED Upgrade
Old 04-04-20, 12:04 PM
  #151
Acrad
Super Moderator
Acrad's Avatar
Received 3,652 Likes on 2,391 Posts
Good catch. That pillar cover is so easy to remove too. I thought there was more holding it than just the bolts for the handle.
Old 04-13-20, 07:46 AM
  #152
oldgx460
oldgx460's Avatar
Default 6k floor lights
I did it, tired of the old yellow so I converted to the 6k white floor lights! But they can be any color you want..
DJtheGR8 (04-13-20)
Old 04-13-20, 04:40 PM
  #153
tecman
tecman's Avatar
Soldered the LEDs in the original housing? More details with parts used please.
Old 04-13-20, 07:45 PM
  #154
oldgx460
oldgx460's Avatar
bought 3mm 3volt leds, disassembled the factory lights and soldered the new leds, the leds under the dash are easy the bulbs pop out of clips, no solder needed.
Old 05-11-20, 04:36 PM
  #155
jaaydee
jaaydee's Avatar
Does anybody have the Part Number for the Socket? On my 2010, the bulb was rusted in the socket.
Thanks,
jaaydee
Old 05-11-20, 05:32 PM
  #156
nuclearn8
nuclearn8's Avatar
[QUOTE=jaaydee;10801368]Does anybody have the Part Number for the Socket? On my 2010, the bulb was rusted in the socket.
Thanks,
jaaydee[/QUOTE
could always try to hardwire in some rigid industries rock lights, they sell a 4 pack. For OEM part number I'd check out the
part numbers sticky @Acrad @jaaydee
Old 05-11-20, 07:07 PM
  #157
jaaydee
jaaydee's Avatar
I think I found the P/N. In another thread, it was listed as 90075-60059. That is a straight connector socket. Doing some digging, I found P/N 90075-60005. I think it would be the correct right angle plug. There isn't enough wire for the straight plug.
I didn't see this in the P/N thread, if I am correct, it would be a good idea to add it.
jaaydee
Old 05-12-20, 05:47 AM
  #158
nuclearn8
nuclearn8's Avatar
once you confirm the correct part numbers please circle back cause as these vehicle age I'm sure their will be other vehicle with corrosion plugs that stop working, especially in the areas that put winter treatment on the roads...
I put di-electrical grease on the backside of every connector on the undercarriage to try to prevent water intrusion (and corrosion) in thru the backside... I realize the connections are waterproof but when I see wires on the vehicle undercarriage going in the back of a connector, it makes me cringe thinking about 15-20 years from now...
Old 05-12-20, 08:05 PM
  #159
Acrad
Super Moderator
Acrad's Avatar
I will make sure these PNs get added to the PN sticky
Old 07-02-20, 10:30 AM
  #160
tonyjh63
tonyjh63's Avatar
Default Interior lights
Just received this 12pc LED interior light kit, and I'm having a bit of trouble. For one, once I got the cover off of the two push-button front map lights, I couldn't get the bulbs out. I can barely get my fingers on them, and I don't know if I need to twist them (which way?). I'm afraid of squeezing too hard and breaking them. Advice?
Thd kit came with this trim gadget thing to use as a pry, but which end do I pry out on the two sets of rear dome lights? Again, I just don't want to break anything...
Lastly, I count 6 bulbs to replace (2 map lights up front, 2 dome lights in the middle, 2 in the back), plus maybe the 2 vanity lights in the visors (I say "maybe", 'cause I'm not sure those 2 lights need to be as bright as LEDs provide). So where are the other 4 or 6 lights supposed to go?
Thanks for any help/advice!
Tony
Old 07-02-20, 11:25 AM
  #161
csrpenfab
csrpenfab's Avatar
Use a piece of packing tape to remove the bulbs. Stick tape to bulb and pull down and it’ll come right out. For the rear and mid dome light, I pried from the rear to remove the covers. You could use the other four for your running board lights or door puddle lights.
tonyjh63 (07-02-20)
Old 07-02-20, 11:44 AM
  #162
tonyjh63
tonyjh63's Avatar
Thankss for the tip - I'll give it a try. So the LEDs aren't too bright for the vanity lights?
Old 07-04-20, 05:35 AM
  #163
Acrad
Super Moderator
Acrad's Avatar
Old 07-04-20, 07:51 AM
  #164
jaaydee
jaaydee's Avatar
They are are fine for the Map Lights, it has been suggested the Vanity / Visor Lights would be too bright with LED's
Old 07-25-20, 11:57 AM
  #165
Chasin
Chasin's Avatar
Have you guys noticed it the LEDs are changing colors overtime? Maybe it's just me but it feels like they are shifting towards purplish shade.
Quick Reply: Interior and Running Board LED Upgrade
