Interior and Running Board LED Upgrade
#166
Super Moderator
I'll haven't noticed but will start paying attention. I used VLEDs in mine.
#167
Super Moderator
Not a fan of the blue LEDs but good instructional video
SRB30A (07-21-21)
#170
#171
I used this kit, its a 10 pack and can do the whole interior. I like how bright they are, a little too bright so I often have to keep them off.
Amazon.com: AUXITO 194 LED Light Bulb 6000K White 168 2825 W5W T10 Wedge 24-SMD 3014 Chipsets LED Replacement Bulbs Error Free for Car Dome Map Door Courtesy License Plate Lights, Pack of 10: Automotive
#172
The Auxitos are best for areas where the light isn't on for much time. They do get pretty hot when on for a longer duration, the heat can degrade the brightness.
Those were the brightest I tested. This was back in Sep 2018. I've only had trouble with one of them. It started to flicker, in a puddle lamp location. This is usually caused by insufficient heat dissipation. The puddle lamps aren't on very long so in this case could be weaker LEDs.
#173
Thanks for the link. Just installed on a 2021 GX. Very bright. Anything brighter for the doors and running boards recommended? I read Phillips are good but they are out of stock on Amazon.
#174
Super stoked to get the domes and doors interior lights swapped out to LEDs.
Can anyone actually confirm which bulbs are in the Vanity light for 2017? I've trolling Google so I can order the right bulbs, but some sights say T10/194/175 and others say that it's a festoon type. I would like to order the right bulbs the first time around, without having to pop the lens cover off more than once.
Are the interior floor lights hard to change too?
#175
or are you referring to the vanity light in the visor? I left mine stock on this
the under seat floor lights can not be easily swapped out so most people leave them. theres a few threads on it if you use the search function a few come up
#176
they are all the same bulb, the wedge bulb 194. it works on all interior and the puddle lights. 10 interior 4 puddle
Bummer on the under seats lights, but I had suspected that they would not be an easy swap out. I will continue to troll this awesome forum! I am learning a lot more than expected about my newly acquired, and most favorite, vehicle!
#178
Thanks, everyone. Even thought I like to stick with DiodeDynamics/VLEDS, Amazon's pricing on AUXITO was too hard to resist. Picked up a set of T10 bulbs I'll throw in the running boards and front doors. Going to keep the rest incandescent to change things up. I have LEDs in my ISF and they are just way too bright at night.
Also grabbed 921 AUXITO bulbs to swap out the reverse lights. Due to the design of the housing on the GX, the bulbs I already have (projector style with added radial chips) have wouldn't produce much usable light output.
#180
the one led upgrade im happy with
bulbs used: SIRIUSLED RLS 7440 7440A Built in Resistor Anti Hyper flashing LED Bulb Turn Signal Light Amber Orange Color Full Aluminum Body Single Filament Error Free Pack of 2
https://1drv.ms/v/s!AtCwYqBVtc77jV0w..._NgYd?e=1yutfK
https://1drv.ms/v/s!AtCwYqBVtc77jV6s...mSrLE?e=gfFX1z
next upgrade will be the reverse lights, and then ill be done.
