SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions
Old 02-03-17, 04:12 PM
  #211
tecman
tecman's Avatar
Request sent for a Sticky with this link that will show my 3 additional links above. Any other requested links for this Sticky?
Old 02-06-17, 11:12 AM
  #212
midwest2
midwest2's Avatar
Originally Posted by stevenatx
I have what seems like a common issue. 2011 GX460
Locked in 4LO, Check engine light with P2442 code. (bank 2)
Changed to a new secondary air pump. Fan and filter on old one was intact. Everything inside was clean.
50a fuse for Air Pump is fine.
With new pump in it still stays in 4LO and Seondary air pump doesn't turn off.
Any suggestions?
Steve
If you have time, order the part on ebay and change it yourself. It's the passenger side valve. Once you get the part in your hands you will easily understand how to replace it or take the easy route and just replace the top half. Good luck! My 2011 malfunctioned around 46k.
Old 02-06-17, 01:09 PM
  #213
stevenatx
10th Gear
stevenatx's Avatar
Thanks.
Anyone have better pictures and instructions on how to replace this valve?
Old 02-07-17, 03:05 PM
  #214
LS430Nole
LS430Nole's Avatar
The switch out is easy. Four screws to remove the top portion of the valve. Remove the hose and electrical connection. Install new top portion of valve, hose and electrical connection and your done. The valve insert may stay connected to the old top half of the valve when you pull it apart or it may stay in the bottom half. You must remove it and replace with new insert. When I took apart my new valve the insert stayed attached to the new top half. DO NOT remove the valve insert from the new valve. It is hard to put back on.
I replaced my pump first back in June 2016 with and aftermarket pump from ebay. My valves started acting up in December 2016. Replaced the valves in December 2016 and two days ago the replacement pump went out again. I removed the pump and found the bottom part of the pump was full of water. Does anyone know how this could have happened?
Valve insert top side.
Valve insert bottom side.
Bottom part of valve with top portion removed.
Bottom portion of valve with insert still sitting in bottom half. You can see the top half of the valve in upper left corner of picture.
Top half of valve.
11GX460 (02-07-17)
Old 02-07-17, 06:30 PM
  #215
11GX460
11GX460's Avatar
Thanks for the pics, LS430Nole.
Old 02-14-17, 02:50 PM
  #216
shapon7
shapon7's Avatar
Originally Posted by psolov
There is a service bulletin for this issue that extends the support for this repair to 5 yr/50k miles. I had the pump fail and one of the valves stuck as well on a 2010 GX460 with a little more than 5yr/50k. I spoke to the dealer on getting the repair comped but was not able to so I called Lexus directly and it took a few days but was able to get the parts covered which was 80% of the cost. Considering that they provided a loaner it worked out.
If anyone needs the SB I'll pull it up. Labor is only 2.3h for pump for the SB and they did cover the valve as well.
Currently I am going through the same issue. Please forward me the service bulletin to me. Thanks Shaikh
Old 02-21-17, 05:57 PM
  #217
stevenatx
10th Gear
stevenatx's Avatar
Default video
hope its helpful
ahmerx (03-18-21)
Old 02-22-17, 06:43 AM
  #218
NewB2Lexus
NewB2Lexus's Avatar
The video does not play, it says it was removed!
Old 03-11-17, 10:29 AM
  #219
stevenatx
10th Gear
stevenatx's Avatar
changed video setting to public. try again.
Old 03-11-17, 10:31 AM
  #220
stevenatx
10th Gear
stevenatx's Avatar
Default Video for secondary air issues
I had posted this before but video setting was on private. Setting changed. Hope this is helpful for someone.
The following 3 users liked this post by stevenatx:
ktranne9 (03-11-17), StrannikMD (03-13-17), tecman (03-11-17)
Old 03-11-17, 11:01 AM
  #221
tecman
tecman's Avatar
Nice
Old 03-15-17, 05:33 PM
  #222
bbqsoup
bbqsoup's Avatar
I've been reading up on this and this was the second mod I did to my new truck. The foam filter is still in good condition but I feel better with the UNI filter.
Old and New
Old 03-16-17, 11:34 AM
  #223
bigphil001
bigphil001's Avatar
So apparently Lexus has finally acknowledged this is a problem and is going to take care of us! I received this letter in the mail and will be seeking reimbursement for the parts!
Attached Thumbnails SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions-20170316_130620.jpg
Jacket (03-20-17)
Old 03-16-17, 01:34 PM
  #224
bbqsoup
bbqsoup's Avatar
Thanks for posting. I wonder if only some VIN's from 2010 got this letter or all of them. Does this also show up on your Lexus driver history account too?
  #225
Booyah
Booyah's Avatar
This is good to know!! My 08 has been ok so far, I have another year for warranty work!!
Quick Reply: SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions
