SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions
#286
Super Moderator
#287
Update:
In the last 2 days I have cleared the trouble and it came up again immediately after driveing. Both bank 1 and 2 are now failing. It is possible to clear the codes while driving with the Carista app to get out of limp mode. Tracking the bypass module shipment and I should have it tomorrow.
#288
Super Moderator
Update:
tecman (05-12-17)
#289
Update:
If I've missed some posts/readings...then please forgive me.
#290
I read this post a few months back when I encountered the same problem and code. I followed the steps from a previous post on here about contacting Lexus 800 number and complaining and was given a service ticket to check in to my issue/complaint. After completing all the required information to them and 6 weeks later, I received a check for the entire amount of the repair. Saving me 2k. So thankful for the earlier post on how to go this route and was suspicious it wouldn't work, but it did and very well!!!!
Thanks!!!!
Thanks!!!!
psolov (05-10-17)
#291
I got the letter but leaving it with the dealer is a hassle for me. I have plenty of time to have it fixed if I choose. If the bypass works with no issues I will be happy. As I mentioned earlier here I plan to keep the truck for a long time and the failure could easily come up again. I prefer bypassing the system to be done with it.
#292
that is awesome, I'm sure you can find a way to put that money to good use. I'm sure this will go a long way to getting everyone on-board in calling Lexus if they don't get satisfaction from their dealer.
#293
Super Moderator
I too plan to keep vehicle a long time and probably need to consider buying a kit to keep on hand once the warranty extension expires.
#294
Next post is a link to directions and a pic of the supplement that was added with my shipment. My understanding is that I don't need the exhaust block-off plates? The acronyms are a little confusing. Look at the first sentence under Installation
The exhaust block-off plates are only to be installed with the SAS (AIP) Bypass Module
#295
#296
GX 460 Hewitt Technologies Bypass Install
Installed and drove around the block. No lights and no codes
Air intake.
Only purple relay in the box.
Ran the cable in front of the engine and took every possible shortcut with the large connectors and only made it to here. When I permanently install it I will try going over the top but looking at the route it won't be as clean looking.
Air intake.
Acrad (05-13-17)
#297
Super Moderator
Putting the wire in wire loom should clean up too. Thanks for post!!
#298
Drove to a customers house and stopped off for lunch on the way home... HELLO trouble lights when leaving the restaurant. Called Hewitt Tech and was told the P2440 and P2442 will always be in the memory due to never being restored and other codes can bring them back up. I was advised that the pump could be bad and would require the $150 pump bypass with P0418 (I had the same code when I disconnected the pump earlier in this thread). P0113 is the odd one, I was advised to pull the connectors off and check for any bent pins or loose connections and was told it could be a bad bypass module and they have had the same problem recently with one.
Pulled the connectors and reconnected and all looks good. I obviously need to have the system replaced and then put the bypass on.
A couple of things to note.
> The bypass has a lifetime warranty with the car.
> The Hewitt technician said that Lexus WAS replacing the entire system with any part failure and are now only replacing individual bad parts with the extended warranty.
#299
I just got the check engine light, anti-splip light, and 4 low light this morning. I'm thinking it's the secondary air issue. Do you know if Lexus will warranty a modified GX? I just recently had it lifted, new wheels and bigger tires.
#300
That mod has nothing to do with the secondary air intake. You are good to go.
