SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions
Old 09-16-17, 04:45 PM
  #346
Acrad
Super Moderator
Acrad's Avatar
Received 3,639 Likes on 2,384 Posts
I may have posted this in another thread but can't remember ... anyway... this should be something the '14-'16 owners should be aware of as they are not out of the woods and could be affected by the air valves sticking from freezing temps. This may affect earlier years as well even though TSB doesn't list it..not sure
Old 09-18-17, 08:15 AM
  #347
Acrad
Super Moderator
Acrad's Avatar
tecman: I was looking closer at the new and old parts pictures you posted.
Does the removeable cap piece now have a ridged section unlike the stock one that was smooth all around? It looks like I see a ridge in the lower left corner of foam on the new cap. Can you confirm?
Old 09-18-17, 08:42 AM
  #348
Acrad
Super Moderator
Acrad's Avatar
I know it only addresses one piece of the failure but I am gonna put one of the Uni filters on there and keep the spare parts in case I need to return to original state. I know it will more likely be the valves that fail.
I really don't like that sponge piece sitting in there.
Amazon Amazon
I notice part numbers are different on '14+ for the air switch valves:
'14+ - 25701-38132 (Right)
'14+ - 25702-38062 (Left)
'10-'13 - 25701-38100 (Right)
'10-'13 - 25702-38050 (Left)
Old 09-18-17, 09:04 AM
  #349
tecman
tecman's Avatar
It has this...
Acrad (09-18-17)
Old 09-18-17, 09:22 AM
  #350
Acrad
Super Moderator
Acrad's Avatar
I was reading some posts elsewhere that part of the fix on Tundras is a re-flash to prevent limp mode in the event of failure.
I have to think '14-'16 TSB above is the same thing. Nothing I've seen for the '10-'13s though. Hopefully the replacement parts fix the issue though.
Old 09-18-17, 05:32 PM
  #351
tecman
tecman's Avatar
Since I took the cover off for this, I removed the internal filter and put on my original external Uni filter. I just have a bad feeling about the internal filter. I do plan to reinstall the bypass.
Old 09-19-17, 08:24 AM
  #352
Romanova
Romanova's Avatar
Originally Posted by Acrad35751;9984834
[url
https://www.amazon.com/gp/product/B003CJOTSA[/url]
+add to cart...
Old 09-19-17, 09:58 AM
  #353
bbqsoup
bbqsoup's Avatar
LOL...over the weekend, as I was refilling the windshield washer fluid, I thought to myself that I probably should put the filter back again and remove the foam because rain season is coming and it may get wet somehow.
Old 09-21-17, 05:26 PM
  #354
Acrad
Super Moderator
Acrad's Avatar
Mine will be here from Amazon order next Tuesday... I will install mine next week. As much as this sucks it is covered by an extended warranty and even beyond that there are some far more reasonable repair cost options. We have the bypass kit option as well as aftermarket parts installed by an independent or shade tree mechanic that are a relative bargain compared to what dealership would charge. I'd probably go bypass myself since the state I live in doesn't do emission checks on anything 2009 or newer.
Old 09-22-17, 01:36 PM
  #355
Romanova
Romanova's Avatar
Hope you have better luck. Amazon sent me an empty box. No filter, just a shipping invoice.... their customer service is sending out another one... just a minor annoyance.
Old 09-23-17, 03:10 PM
  #356
tecman
tecman's Avatar
Default Bypass module
Quickie install done over the top today. I'll see what happens tomorrow with a cold start.
Old 09-23-17, 04:00 PM
  #357
Acrad
Super Moderator
Acrad's Avatar
tecman: Doesn't the bypass have exhaust block off plates as well? If so...are those fairly easy to put in?
Old 09-23-17, 05:01 PM
  #358
tecman
tecman's Avatar
Post 41 and 42 indicates that I don't need them. The system is functional so no need for the block off plates.
https://www.clublexus.com/forums/gx-...k-miles-3.html
I thought I had an email from Hewitt to confirm this but can't find it. Perhaps it was a personal email so search results do not work.
I will report back with results....
Old 09-23-17, 07:31 PM
  #359
Romanova
Romanova's Avatar
Was the filter supposed to be black from the factory? Popped my cover off today and mine is a reddish/brown color. No signs of degradation and I spun the little fan blade and it was clean and clear...
Old 09-24-17, 01:44 AM
  #360
Acrad
Super Moderator
Acrad's Avatar
I think it is more a darker color... not sure about black though. tecman has a picture or two of his replacement foam in earlier posts.
I was thinking more about this other day and scenarios that could draw the foam into fan. Mine seemed solid as well but I didn't immerse it in water either to see what form it took. In addition if water was introduced through whatever means does that air pump have enough draw or vacuum to simply pull existing foam out of rest spot and into the fan blades? Or does it only take a small amount of water for the foam form to collapse and be drawn toward the vacuum?
This seems to be an area one wants to cover up if they frequently wash their engine bay. The TSB and later years add the cover to reduce water intrusion but this would seem to only address water from the top. Off-roaders and/or water from the bottom could still cause intrusion... even '14+ for that matter.
Just a lot of speculation on my part and potentially self-justifying the addition of the aftermarket filter and pulling the foam out on mine. :-)
EDIT: Perhaps even water forced up through some automatic car washes for the underbody spray program of the wash sequence?
Quick Reply: SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions
