SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions
#541
For more that a year now, the check engine, slip indicator and 4Lo lights are on for my Lexus GX 460. Initially driving was normal and you will not notice any problem. Recently how,when the check engine light begins to blink, the car cannot accelerate beyond 80km/h. I have try several diagnosis,where the scanner is placed on the vehicle's computerized system. Sometimes, when these lights clear, within one hour drive, they reappear. What can be the problem?
#542
Well, finally it is my tune now. This afternoon, as I was driving, the check engine light came on, and "traction off" displayed in the cluster. No flashing 4-Lo yet, but definitely reduced power with very rough idle. Anyway, call the dealer, will have tow truck tomorrow morning and getting it taking care of.
bbqsoup (04-08-19)
#543
Acrad (04-09-19)
#544
The GX is at dealer now. Will be sure to update the group here with the final. They said should be done by Thursday due to busy schedule and workload. Since I have the loaner (2019 RX350L), and I am fine and no particular hurry anyway.
#545
... and now it won't start.
I've been following a few threads on this forum for several months now. It has been a wonderful resource! I thank you all for that.
The original part (secondary air pump) with the filter clogging the fan and outlet. Filter removed in the late fall.
That lasted for several months. This spring, when there were still some cold days, the car started to have problems again and the indicators seemed to point at the same problem we had in the spring.
The after market component (secondary air pump) with external filter modification. Component installed in the early spring.
The issue appear to be fixed again, but that only lasted a short while. A few weeks later the car was having the same behavior. The code reader was showing P2442 again. I got my wife a rental and would drive the GX for short errands to see if I could figure out what was going on. It was during this time that the car stalled on me while I was driving it. It wouldn't start after that. I didn't want to cause damage trying to start it repeatedly, so I just got it towed home.
I decided to simply replace both air valves too. With guidance / inspiration from this post, I ordered both valves and new gaskets. I got OEM parts this time. The old valves looked a lot like the other posts I see talking about the P244# problem.
The upper chamber of the secondary air switching valve - bank 2 (passenger side).
The lower chamber of the secondary air switching valve - bank 2.
I installed the new valves and put everything back together. At this point, I was expecting the car to start-up and run, but that is not what happened.
I borrowed a scanner and it appeared to indicate the secondary air valve (bank 2) was stuck open. In hindsight, it might have been telling me that was the issue before I installed the new valves and it just hasn't cleared yet because I haven't been able to start the car and run it through the cycle it would need to verify that the reported issue is indeed resolved.
Currently I'm working my way through the components of the air system and using a service manual from ChiltonDIY.com to guide me on how to verify that individual components are working. Everything has been passing thus far. I think I'm in the weeds though and I could use some help. I have two specific questions, but I would appreciate any expert guidance.
The current state of things:
My questions:
In lieu of any recommendations that need the valve uninstalled, I'm going to start putting things back together.
Spoiler
- I have a 2011 GX 460.
- My wife drives the car daily, so information on what was happening leading up to any issue is second-hand and limited.
- Last fall, there was a problem with the car. Google searches and this forum led me to the secondary air pump.
- Upon inspecting the air pump I found that the fan was gummed up by, what used to be, the filter. Unlike other threads that discuss this problem, I did not detect any moisture in any part of the lower chamber of the air pump, the upper chamber of the air pump, nor in the tube at the connection to the air pump.
- I inspected the tube that connected the air pump to the valves, but only up to the "Y" connector. I could not detect any evidence of the disintegrated filter in the tube nor in the connector.
- I removed every bit of filter from the upper chamber of the air pump.
- I reconnected the air pump and the car appeared to run fine.
- I got a code reader and confirmed P2442 was being reported.
- I learned more about the purpose of the air pump and "limp mode".
- I discovered that clearing the codes seemed to return the car to normal.
- At this point, I assumed that the air pump, being needed to start the car on cold mornings, had finally died. I found an after market replacement for the air pump. Per a suggestion I saw on this forum, I removed the filter from the new part and put an external filter over the intake of the new pump.
- When the GX wouldn't start, I got some starter fluid and tried a few more times.
- It felt like there was ignition, but it didn't didn't feel like it was actually "running".
- I put the battery on a charger to make sure that it was strong and fully charged.
- Still couldn't get the car to start.
- I have the battery disconnected, the bank 2 air valve removed, and parts of the air filter system removed too.
- I got my own ODB2/EOBD Scanner delivered last night, but haven't run it yet since I have parts taken out.
My questions:
- While I have these components out the spark plugs, one one side, are easy to reach. Should I take advantage of this state and inspect the plugs? If so, what should I do and what am I looking for?
- When the engine wasn't starting I did hear a sound that I couldn't interpret. It was a buzzing that was audible after the ignition sequence had stopped trying to get the car to turn over. It is possible that it is a normal thing and I just have never noticed it before. As best as I could tell, the sound was coming from the electronics connected to the throttle body (I think that is what you call it). Does this mean anything to you guys? I have a video that shows what I am talking about. I'll post it below.
#547
Great post, thanks!! If you are using CL pic/video option to upload a video I have had problems. If it is a YouTube video you must SUBMIT REPLY the link for CL software to process it and show the video.
#548
#549
Super Moderator
There is a 10-13 FSM in this post.
https://www.clublexus.com/forums/gx-...-gx-460-a.html
Remember that air system on your GX has a warranty extension of 10 years / unlimited mileage from warranty inception date.
#550
Thank you for the input, Techman and Acrad.
Yes, I was using the CL upload for the video. If you think that it might be relevant to why I was having trouble starting the car, then I'll put it up somewhere that you can see it.
Thank you for pointing out the Spark Plug Well Filled with Oil issue. I'll check that out.
Finite State Machine? I'm sorry, I don't understand what you are saying here.
Have I voided that warranty now that I've been messing around under the hood? I am the second owner of this car. I've read that some services aren't available to me since that is the case. If I have that wrong, any pointers would be welcome. I don't mind doing the work though. I happen to have the time right now and except for the fact that the car didn't start when I put it back together it has been rather enjoyable.
#551
Super Moderator
It's a factory repair manual that will be more detailed than the Chiltons. This warranty would follow all owners up to expiration. I gotta be honest I don't think Lexus dealer would touch it seeing aftermarket parts on there now. It would likely have to be reverted back to the original parts in a failed state for extended warranty coverage to apply on the air pump system.
Craigyyy (04-22-19)
#553
Super Moderator
It's worth a shot but I know you already bought the parts but you could try reselling parts too.
There are bypass units as well for 10-14 models.
https://hewitt-tech.com/store/index....ct_detail&p=44
John00 (04-20-19)
#554
Thanks for sharing that manual!
Would someone confirm that their AI-VSV relay harness passes this test. I get 0V when I measure between terminal 2 and body/ground.
The relay itself passed. This is for the socket in which the relay sits; as the manual says, the "harness" or "connector". Do you read 11V - 14V?
#555
This is a $2,000+ repair. I had a 2012 GX that threw this error code 6 days after the new car warranty expired. Lexus repaired it at no cost to me. A few months later I got a letter saying that this part and all labor to repair it was going to be done free of cost for a period of ten years from initial in service date. It's best if you take it to them and let them repair it at no cost to you.
