SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions
Old 05-14-19, 03:53 PM
  #601
Acrad
Super Moderator
Acrad's Avatar
Received 3,639 Likes on 2,384 Posts
Mileage limits changed last year sometime as my letter in different thread shows 10 years from date of first use regardless of mileage.
https://www.clublexus.com/forums/gx-...l#post10250331
Old 05-14-19, 03:59 PM
  #602
tecman
tecman's Avatar
Keep that letter as evidence
Acrad (05-14-19)
Old 05-14-19, 04:03 PM
  #603
Acrad
Super Moderator
Acrad's Avatar
Oh...I've got it in a safe place. :-) If... or should I say "when" system fails I will go with the Hewitt-Tech like you did.
Your experiences with this failure has given everyone good info on temporary bypass of resetting codes and unplugging the air pump. I keep a cheap OBD reader (assuming my phone isn't with me) in rig to reset codes for the day and keep myself out of limp mode.
tecman (05-14-19)
Old 05-25-19, 08:59 AM
  #604
randflagg
randflagg's Avatar
Bumping this up. Lexus recently did the 90k service to my 2010 and replaced the secondary air injection pump and filter housing under warranty while it was in the shop. The tech said that there is now an open recall and the unit doesn't have to have failed to be replaced.
mike2937 (06-04-19)
Old 05-25-19, 09:24 AM
  #605
Acrad
Super Moderator
Acrad's Avatar
I haven't seen any recall notices yet or any updated TSBs.
I wonder if this was a goodwill repair since you were paying for a 90K mile service and close to the 10 year cutoff on the secondary air warranty extension?
Old 05-25-19, 09:28 AM
  #606
randflagg
randflagg's Avatar
That could certainly be the case. However, the way he and his service manager talked about it made it seem like the notice is something they only recently had received and they didn't expect to do many of them. Mine was the first one they have done.
Old 05-25-19, 09:39 AM
  #607
Acrad
Super Moderator
Acrad's Avatar
Mine still hasn't failed but I expect it to someday. I would definitely take mine in if this was now an open repair that could be done on demand
There were 51,234 (10-13 GX 460) sold in US and this isn't an uncommon failure on GX 470s, Tundras, etc so they will see others.
Old 05-25-19, 09:52 AM
  #608
randflagg
randflagg's Avatar
^ It didn't show up in my Lexus Drivers portal either. Might be worth asking around at your local Lexus service centers.
Acrad (05-25-19)
Old 05-25-19, 12:19 PM
  #609
smithpr2
smithpr2's Avatar
Default 2012 GX460 Secondary Air Injection Warranty - Towing Exp.
The 4LO and engine light came on today and car slowed down. Took to Toyota dealership since no Lexus dealership around. They confirmed it was under secondary air injection warranty but had to be done at a Lexus dealership. Closest one is 160 miles away. Will Lexus pay for towing? Just checking before I do anything. Toyota will fix for @$1600 and I've read that Lexus will reimburse but that may take a long time. Just wondering about towing expense. Thanks
Old 05-25-19, 12:38 PM
  #610
Acrad
Super Moderator
Acrad's Avatar
You probably want to contact that Lexus dealer and look at options. Dealer here also offered to send a flatbed for pickup.
https://www.clublexus.com/forums/gx-...l#post10056107
Old 05-25-19, 12:46 PM
  #611
smithpr2
smithpr2's Avatar
Thanks for quick response and information link. Will call Lexus and put the wheels in motion.
Old 05-28-19, 11:06 AM
  #612
stretton
stretton's Avatar
Default secondary air injection pump recall - limp mode afterward
I just bought a 2010 GX 460 base with 92k miles a few weeks ago. I got a pre-inspection done at a Toyota dealership and immediately had the secondary air injection pump recall performed at my local Lexus dealership. Within just a week it went into limp mode. I took it in and the following codes appeared: P0441, P0455, P0456. The dealership said it was not related to the recall service.Then - just yesterday - limp mode again. The service center was closed due to memorial day, so I just disconnected the negative terminal on the battery and reconnected it which did the trick.
I'm hoping this won't become an ongoing issue, but I have to think that it will since it has happened twice within the last couple weeks. Anyone else have any ideas/words of comfort?
Old 05-28-19, 11:14 AM
  #613
Acrad
Super Moderator
Acrad's Avatar
Old 05-28-19, 12:00 PM
  #614
stretton
stretton's Avatar
Yeah - here are the technician's comments: TECHNICIAN INSPECTED ALL EVAP SYSTEM HOSES AND LINES, ALL HOSES ARE GOOD AND TIGHT TECHNICIAN CLEARED ~ ~TECHNICIAN CLEARED THE CODES AND PERFORMED EVAP SYSTEM MONITOR TEST, TEST PASSED AT TIME OF INSPECTION SECONDARY AIR SYSTEM IS ALSO IN PASSED STATUS FINAL TEST DRIVE WAS PERFORMED TO VERIFY NORMAL OPERATION
Old 05-28-19, 12:08 PM
  #615
Acrad
Super Moderator
Acrad's Avatar
How does seal or gasket seem on your fuel cap?
Quick Reply: SAIP - Service Campaign (JLG) '10-'13 / Update: No mileage or year restrictions
