How do you disable dash lights after removing air suspension/AHC?
Old 05-07-20 | 06:52 PM
  #61
Acrad's Avatar
Acrad
Super Moderator
It was a 460... I will see if I can track down post...
Old 05-07-20 | 06:59 PM
  #62
Acrad's Avatar
Acrad
Super Moderator
https://www.facebook.com/groups/Lexu...3617820435992/
GXOR Post
KJ6IRM (05-07-20)
Old 05-08-20 | 05:22 AM
  #63
nuclearn8's Avatar
nuclearn8
Originally Posted by nuclearn8
Why don't you just remove the air compressor or pull the fuse so it doesnt run....
I want to apologize for being that guy and not reading the entire thread before posting. I had no idea this was such an issue when converting the suspension.... again apologies. I hope those who want to or have converted their suspension find a solution.
The dash lights and warnings would drive me crazy as would leaving unused equipment that could kick on and drain the battery...
Old 05-08-20 | 06:56 AM
  #64
KJ6IRM's Avatar
KJ6IRM
No need to apologize.. were all here to learn about our trucks, and this is a log thread to go through.
Old 05-08-20 | 09:26 AM
  #65
Acrad's Avatar
Acrad
Super Moderator
It probably is some resistor or ground that needs to be in place. Discovery of that will take time and would be one the the better overall scenarios.
Haven't some just disconnected the height sensors and tied them up in a way that they don't adjust at all?
Old 05-08-20 | 11:53 AM
  #66
KJ6IRM's Avatar
KJ6IRM
if you do that, then the AFS headlights don’t work properly. I don’t want to blind people or have my headlights pointing straight at the ground.
Acrad (05-08-20)
Old 05-08-20 | 02:24 PM
  #67
Acrad's Avatar
Acrad
Super Moderator
I see your point..even if you can override and remove the compressor the rear height sensors are there still sending data for the AFS system
Old 05-08-20 | 04:05 PM
  #68
oldgx460's Avatar
oldgx460
Spoke with the guy on GXOR and he disconnected the power to the air pump and removed the valve that is on the pump and left it connected. After he did this he did not have any messages and no more air pump. You can probably just run a resistor across the valve connector and disconnect the power plug and be done with the air pump.
Old 05-09-20 | 08:18 AM
  #69
Acrad's Avatar
Acrad
Super Moderator
Suspension Control ECU values
Old 10-26-20 | 06:36 AM
  #70
jmhetzel's Avatar
jmhetzel
Default Compressor quit working. Dealer wants $2500
I got the dreaded "Check Air Suspension System" dash light on my 2011 GX460 Premium. It only has Air suspension on the rear. The dealer says it needs a new compressor and the part is $2500 plus labor, and they can't guarantee the rest of the system is ok until the replace the compressor. The dealer wouldn't put a air to coil spring conversion kit on it so I did it myself. https://suncoreindustries.com/produc...s-lexus-toyota kit. https://suncoreindustries.com/product/18140/air-suspension-air-to-coil-spring-conversion-kit-with-gas-shocks-rear-pairs-lexus-toyota
I even put the bypass resistors in. So my question is how do I get rid of the " Check Air Suspension System" error since the compressor isn't working. I left everything hooked up for now. The vehicle rides as good as it used to so in that way I'm happy. Now to get rid of this error. Any help would be appreciated.
Old 10-26-20 | 06:41 AM
  #71
Acrad's Avatar
Acrad
Super Moderator
Rear suspension height sensors as well as compressor still have to stay attached. Some have connected just the electrical pieces of compressor. If the faulty compressor is triggering it...I don't know a workaround to that at this time.
Those resistors just address the shocks and not the RAHC (airbag system)
Old 05-10-21 | 09:39 PM
  #72
Dazed's Avatar
Dazed
Possibly starting an old thread. I am about to remove the bags and add coils. I was reading up on this and then started perusing the FSM, as one casually does on a Monday evening. So I noticed that there is a Height Control ON/OFF switch in the Combination Switch Assembly (always there wired but only sometimes present as an actual switch). I looked into the wiring diagram and the "switch" is present. If the switch is not physically there, it would be an "open" and present to the ECU as ON. Is dealing with this as "easy" (since taking apart the center consul is so easy) as typing pin 16 to pin 9 (ground) making the switch look "closed" and in the OFF position? Another option would be to get a combo switch assembly with the physical switch and then press it to OFF.
This "fix" would stop the air compressor from turning on if/when the load on the rear axle was enough to move the sensors and cause us not to have to add in the washer spacers. (Also, not removing/disconnecting anything as per this thread https://forum.ih8mud.com/threads/201...error.1101964/)
Also posted here: https://forum.ih8mud.com/threads/rea...gx460.1199884/
Old 05-11-21 | 05:44 AM
  #73
Acrad's Avatar
Acrad
Super Moderator
AFAIK... that Off button request is overridden once you get above that 18-20MPH mark.
You could easily test holding it down (continuity ~ 0 ohms) so you see OFF displayed on height display and then see it overridden at speed.
John00 (05-13-21)
Old 05-13-21 | 05:45 PM
  #74
John00's Avatar
John00
do you want to disable a dash light or fool the vehicle into thinking there is a compressor in the circuit yet not have a compressor run? or something else? seems like a simple workaround.
Old 07-30-21 | 05:06 AM
  #75
Acrad's Avatar
Acrad
Super Moderator
This may help someone dial in rear height sensors after a lift. You will still likely need to leverage the washers discussed in thread.
Height control adjustment parameters
IMO: Get within 2.3-2.6V range since over 18-19MPH it defaults to this range.
Quick Reply: How do you disable dash lights after removing air suspension/AHC?
