How do you disable dash lights after removing air suspension/AHC?
#76
Super Moderator
You shouldn't get any lights or notifications on the dash. If you run a full Techstream or OBDLink scan you will find codes related to the missing shocks but just a side effect of removal.
Hehena (08-26-21)
#77
Similar air issue
I did a airbag to coil-spring conversion and I could hear the air compressor running when I checked the height adjustment switch. I haven't attempted to remove power or fuses, but I am concerned the motor will eventually burn out and I'll end up with errors. Did anyone come up with a fix?
#78
Super Moderator
Were you trying to manually adjust the suspension?
If you have suspension set where it isn't normally going off you could always look at de-pinning the connections to the console switch for the suspension.
Unfortunately the closest I have seen to compressor delete was a member of GXOR who gutted the motor of the compressor motor itself but left all of the other compressor electrical intact. I never heard specifics of what he did though to the compressor.
Removal of fuses or relays will result in errors though.
#79
Acrad (09-12-21)
#80
After removing the air suspension, doing the spacer trick, and putting in crawl control (with no air suspension controls), I had no error messages, but I did hear the compressor from time to time. I have no idea how often it was running but I noticed my battery getting lower over time. It was time to get rid of the compressor!
Here’s the deal- you can remove all of it, just not the solenoid. It was a pain, but the compressor is out, the solenoid remains, and everything is working well. The only image I could find for the job was the stock image below so I’ve added some of mine. You can see what was removed and what remains.
I could have removed more things (lines, etc.) but I didn’t bother. The good news is that I won’t hear the air compressor again because it ain’t there. 👍🏼
#81
Super Moderator
Thanks you!
A few have reportedly done this over the years but never documented to this detail.
#82
Super Moderator
GXOR member reported this to get rid of the compressor
http://www.facebook.com/groups/Lexus...09801942484238
nuclearn8 (01-13-22)
#83
@EverD Have you tried this? Do you still have your height sensor? This can reportedly address the air pump
https://www.clublexus.com/forums/gx-...l#post11202694
#84
Super Moderator
Did you leave the height sensors in place? I haven’t seen any tricks to remove those entirely but only modified.
What specific codes are you pulling with with Techstream or OBD Link?
