Differential and Transfer Case Fluid Change
Old 06-01-21, 02:06 PM
  #256
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
Received 3,671 Likes on 2,401 Posts
This is 2021 warranty services guide but the same since 2010.
30k mile intervals suggested for front diff, rear diff, and transfer case
Old 06-01-21, 02:59 PM
  #257
Romanova
Romanova's Avatar
Even at that interval, the cost of the TC fluid isn't that bad...
Guess I'm about due for a fluid service for these three items again.
Acrad (06-01-21)
Old 06-04-21, 06:46 AM
  #258
Romanova
Romanova's Avatar
Originally Posted by Acrad
Mine came out without issue the 2 times I have serviced front diff but I did replace with the KAON 24mm drain plug
https://www.kaon.com.au/?rf=kw&kw=24mm
They do make an extraction tool as well as seen at this link above.
Remember AUD pricing so cheaper than what it seems.
Ended up being $36.90 in US dollars to get this part including the $0.37 international service fee for using Visa. See how quickly it gets here now...
Old 06-04-21, 07:44 AM
  #259
BigLClub
BigLClub's Avatar
thread size?
What is the thread size on the 24mm plugs?
thx
Old 06-05-21, 01:26 PM
  #260
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
Old 07-26-21, 08:20 AM
  #261
chrisca70
chrisca70's Avatar
Default A few tips on the differential and transfer case service
Just did my differential and transfer case fluid change at 110k miles, thanks @Acrad and participants for all the info! It may be useful to update the OP, with the fill/drain plugs torque and may be fluid alternatives to minimize time fishing the info through the thread. Here are some tips that may help:
  • If you have an oil extractor pump, you will only need to remove the fill plug. I used mine an it was nice and easy and contained all the fluid in the pump.
  • To fill the differentials/T.case: I used a hand pump which was ok but I had to pump a lot. I will invest in a transfer pump for next time, which I can also use for transmission fluid change.
  • Front differential: you do not need to remove any skid plate if you have the pump. There is enough space to access the fill plug to remove it and to fill the fluid.
  • Transfer Case: good time to inspect any leaks. Mine had a slight leak seemingly coming from the front seal.
Fluids for front and rear differentials: I used Mobil 1 Synthetic 75W90 for front and rear differential, many users report this on several Toyota forums without and problems.
Fluids for Transfer case: I used Red Line Synthetic 75W MTF, now labeled with the same part number as the Toyota 75W fluid.
Crush washers: Purchased a kit from Amazon for $7.99
CaptRussia (08-27-21)
Old 07-26-21, 01:12 PM
  #262
Romanova
Romanova's Avatar
Holy smokes, still waiting. Took almost 6 weeks to leave Australia. Not sure what happened... the vender helped out and it finally got moving so hopefully it will be here soon. Not sure if it was a fluke, but if you're going to use this, make sure you order well in advance!
Old 07-26-21, 03:26 PM
  #263
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
Crazy shipping times from both sides of the spectrum... totally not related but wife wanted this Monkee Tree cat tower for our British shorthairs... anyway... 5 days from order to delivery from New Zealand to WA state via DHL last week.
Old 07-26-21, 05:24 PM
  #264
skrypj
skrypj's Avatar
Lexus sells a drain plug with a nut/hex on it. Its from the IS350 AWD I believe and is a direct replacement. I put it on mine after my stock plug stripped out. I am pretty sure its like $5.
90341-24016 is the part number.
The following 2 users liked this post by skrypj:
bbqsoup (07-27-21), S2k4 (09-06-21)
Old 07-26-21, 07:11 PM
  #265
WRD4chano
WRD4chano's Avatar
most likely a fluke, my order from kaon took two weeks to get here.
Old 07-27-21, 09:02 AM
  #266
bbqsoup
bbqsoup's Avatar
Just ordered this plug. I'm at 79k miles now and plan to change the diff again at 100k.
william489 (08-03-21)
Old 08-01-21, 08:19 PM
  #267
bbqsoup
bbqsoup's Avatar
So I received the drain plug, do you need a washer with it? What kind do you use?
Old 08-27-21, 10:21 AM
  #268
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
I changed my transfer case fluid again. Last time was back in mid 2017 and about 35k miles ago.
My original fluid was fairly clear... this change it was noticeably darker at around the same mileage.
The original owner never towed or took off-road so that may play a role in it. I had to drop my rear Budbuilt skid over transfer case but not a big deal with a floor jack to help support it.
I did give it the golden fluid as someone is bound to ask. :-)
The following 4 users liked this post by Acrad:
CaptRussia (08-27-21), NewB2Lexus (09-11-21), nuclearn8 (08-27-21), Romanova (08-27-21)
Old 08-27-21, 11:12 AM
  #269
GXLUX
GXLUX's Avatar
What fluid did you drain out? More Unicorn juice or the Ravenol?
Old 08-27-21, 11:14 AM
  #270
Acrad
Super Moderator
Senior Moderator
Acrad's Avatar
As GXBOB calls it ...more "Unicorn poop and Bigfoot tears" :-)
The following 2 users liked this post by Acrad:
nuclearn8 (08-28-21), S2k4 (09-06-21)
Quick Reply: Differential and Transfer Case Fluid Change
